ItemGroup
Résumé
ItemGroup provides access to group level information for a UniqueValueRenderer.
Discussion
The ItemGroup class allows you to change a heading value for a group and more importantly provides access to the individual items in each group.
Propriétés
Nom Explication Type de données
heading
(Lecture et écriture)
Gets and sets the heading string for the group.
String
items
Gets and sets a list of Item or RasterItem objects associated with the group.
Object
Exemple de code
ItemGroup example
The following script first changes the renderer to a UniqueValueRenderer. Next, it sets the fields property to use a single field called Percent. It next iterates through each Item in each ItemGroup and sets the RGB color to red and the alpha, or opacity, value to match the Percent value of each feature. Finally, it labels each value, sets the symbology back to the layer and saves the output.
import arcpy, os, sys
relpath = os.path.dirname(sys.argv[0])
p = arcpy.mp.ArcGISProject(relpath + r'\\UniqueValue.aprx')
m = p.listMaps('Map')[0]
l = m.listLayers('PercentCover*')[0]
sym = l.symbology
sym.updateRenderer('UniqueValueRenderer')
sym.renderer.fields = ['Percent']
for grp in sym.renderer.groups:
    for itm in grp.items:
        transVal = itm.values[0][0] #Grab the first "percent" value in the list of potential values
        itm.symbol.color = {'RGB': [255, 0, 0, int(transVal)]}
        itm.label = str(transVal) + '%'
l.symbology = sym
p.saveACopy(relpath + r'\\SavedOutput.aprx')
