RasterStretchColorizer
Résumé
Represents a raster stretch colorizer.
Discussion
The raster stretch colorizer stretches values along a color ramp. The properties behave in a similar manner to the options exposed in the application. For example, changing the StretchType will control a subset of additional parameters that can be modified.
Propriétés
| Nom | Explication | Type de données |
band (Lecture et écriture) |
An integer that represents a zero-based index matching the order of the bands the way they appear in the Symbology pane. The topmost band is index 0 and the bottommost is n-1. |
Integer |
colorRamp (Lecture et écriture) |
Provides access to the ColorRamp object. |
ColorRamp |
gamma (Lecture et écriture) |
A double that represents the gamma value. |
Double |
invertColorRamp (Lecture et écriture) |
A Boolean that reverses the color ramp's appearance. |
Boolean |
maxLabel (Lecture et écriture) |
A string that represents the raster stretch maximum label that appears in the Contents pane or legend. |
String |
maxPercent (Lecture et écriture) |
A double that represents the percentage of highest values to cut from the source data. This parameter is only applied if the |
Double |
minLabel (Lecture et écriture) |
A string that represents the raster stretch minimum label that appears in the Contents pane or legend. |
String |
minPercent (Lecture et écriture) |
A double that represents the percentage of lowest values to cut from the source data. This parameter is only applied if the |
Double |
standardDeviation (Lecture et écriture) |
A double that represents the standard deviation value. This parameter is only applied if the |
Double |
stretchType (Lecture et écriture) |
A string that represents a valid stretching algorithm. The valid values are as follows:
String |
type (Lecture seule) |
Returns a string that represents the colorizer type. |
String |
Exemple de code
The following script first tests whether the layer's symbology supports a colorizer property, then confirms whether the renderer is a RasterStretchColorizer. Next,. it changes the stretchType to PercentClip and sets the appropriate min/max percents. Finally, it changes ColorRamp to a color ramp named Bathymetry #2.
p = arcpy.mp.ArcGISProject('current')
m = p.listMaps('RasterStretch')[0]
for l in m.listLayers():
if l.isRasterLayer:
sym = l.symbology
if hasattr(sym, 'colorizer'):
if sym.colorizer.type == 'RasterStretchColorizer':
#Set StretchType = PercentClip
if l.name == "Photo_SE":
sym.colorizer.stretchType = "PercentClip"
sym.colorizer.minPercent = 1.0
sym.colorizer.maxPercent = 1.0
cr = p.listColorRamps('Bathymetry #2')[0]
sym.colorizer.colorRamp = cr
sym.colorizer.invertColorRamp = True
sym.colorizer.gamma = 2
sym.colorizer.minLabel = "Min: " + sym.colorizer.minLabel
sym.colorizer.maxLabel = "Max: " + sym.colorizer.maxLabel
l.symbology = sym
