ClosestFacilityInputDataType
Résumé
Enumeration of input types for the ClosestFacility solver.
Propriétés
| Nom | Explication | Type de données |
Incidents (Lecture seule) |
Specifies the incidents to be used as input for the Closest Facility analysis. |
Object |
Facilities (Lecture seule) |
Specifies the facilities to be used as input for the Closest Facility analysis. |
Object |
PointBarriers (Lecture seule) |
Point barriers that temporarily restrict traversal across or add impedance to points on the network. |
Object |
LineBarriers (Lecture seule) |
Line barriers that temporarily restrict traversal across a line. |
Object |
PolygonBarriers (Lecture seule) |
Polygon barriers that temporarily restrict traversal or scale impedance on the parts of the network they cover. |
Object |
