DirectionsCustomizer
Résumé
A base class for a directions customizer.
Discussion
This class is used as the base class when creating a directions customizer class (class MyCustDirs(arcpy.nax.DirectionsCustomizer)).
Méthodes
attach(network_query)
Verifies that the direction customizer can be attached to the network.
It is invoked when the direction customizer is attached to the network dataset. It may be invoked multiple times depending on the number of threads accessing the network.
| Nom | Explication | Type de données |
network_query |
The network query instance for the current network dataset. |
NetworkQuery |
Valeur de retour
| Type de données | Explication |
Boolean |
True, if the direction customizer can be attached to the network dataset |
customize(directions_query)
Customizes the final directions output.
It is invoked by the directions engine once per route.
directions_query |
The directions query instance for the current route. |
DirectionsQuery |
