GetTravelModes
Résumé
Returns a dictionary of travel mode objects that are available with the network data source. The dictionary keys are the names of the travel modes, and the dictionary values are the travel mode objects. The first item in the dictionary is the network's default travel mode.
Discussion
One or more travel modes can be defined on a local network dataset or on a network data source from an ArcGIS Enterprise or ArcGIS Online portal or stand-alone ArcGIS Server site. This function can be used to populate a value list with the available travel modes given a network data source. For example, a geoprocessing script tool may have a parameter of type String called Travel Modes that can be populated with a list of travel mode names when a network dataset has been selected on the tool dialog box.
Syntaxe
GetTravelModes(network_dataset_path)
Le paramètre Explication Type de données
The network dataset or service from which to retrieve travel modes. The argument can be specified using one of the following options:
String
Valeur de retour
Type de données Explication
Dictionary
A dictionary whose keys are the travel mode names and whose values are the travel mode objects. The first item in the dictionary is the network's default travel mode.
Exemple de code
GetTravelModes example 1
Get the travel modes in a network dataset and print the walking time travel mode.
import arcpy
nds = 'C:/Data/SanDiego.gdb/Transportation/Streets_ND'
travel_modes = arcpy.nax.GetTravelModes(nds)
print(travel_modes['Walking Time'])
GetTravelModes example 2
Create a list of travel mode names on ArcGIS Online. The names could be localized, depending on the user's account setting.
import arcpy
travel_modes = arcpy.nax.GetTravelModes("https://www.arcgis.com/")
travel_mode_names = [travel_modes[mode].name for mode in travel_modes]
GetTravelModes example 3
This sample shows how to get a travel mode from a network and print some of its properties.
import arcpy
network = r"C:/Data/SanFrancisco.gdb/Transportation/Streets_ND"
# Get all travel modes from the network dataset
travel_modes = arcpy.nax.GetTravelModes(network)
# Print the impedance attribute and restrictions used for each travel mode
for travel_mode_name in travel_modes:
    travel_mode = travel_modes[travel_mode_name]
    print(travel_mode_name)
    print("Impedance:", travel_mode.impedance)
    print("Restrictions:", ", ".join(travel_mode.restrictions))
    print("")
GetTravelModes example 4
This sample shows how to clone a travel mode from a network, update its properties, and use it in an analysis.
import arcpy
# Construct a new TravelMode object from the existing Driving Time travel mode
new_travel_mode = arcpy.nax.TravelMode(travel_modes["Driving Time"])
# Update the useHierarchy property to turn hierarchy off, and update the name
new_travel_mode.name = "Driving Time without Hierarchy"
new_travel_mode.useHierarchy = "NO_HIERARCHY"
# Use the new travel mode object when constructing an OD cost matrix analysis
od_object = arcpy.nax.OriginDestinationCostMatrix(network)
od_object.travelMode = new_travel_mode
GetTravelModes example 5
The following code sample shows how to call GetTravelModes for a routing service on a stand-alone ArcGIS Server site.
Learn more about how to specify a routing service info dictionary
        "utilityUrl": f"https://mysite.mydomain.com/:6443/arcgis/rest/services/MyRouting/NetworkAnalysisUtilities/GPServer",
        "authenticationInfo": {
            "username": "my_username",
            "password": "my_password"
