GetWebToolInfo
Résumé
Returns the description of the network dataset used for the analysis and the run limits for a tool in the routing utility services registered with your portal or stand-alone ArcGIS Server site.
Discussion
The GetWebToolInfo function allows you to get the tool limits or information for the network data source used by your portal.
Syntaxe
GetWebToolInfo(service_name, tool_name, {portal_url})
Le paramètre Explication Type de données
service_name
The name of the service containing the web tool.
Valid values are as follows:
  • asyncClosestFacility
  • asyncFleetRouting
  • asyncLocationAllocation
  • asyncODCostMatrix
  • asyncRoute
  • asyncServiceArea
  • asyncVRP
  • syncVRP
The values are case sensitive. A ValueError exception occurs when the service_name value is not in the list of supported values.
String
tool_name
The name of the web tool.
Valid values for each service_name value are as follows:
Field
FindClosestFacilities
asyncFleetRouting
SolveLastMileDelivery
SolveLocationAllocation
asyncODCostMatrix
GenerateOriginDestinationCostMatrix
asyncRoute
FindRoutes
asyncServiceArea
GenerateServiceAreas
asyncVRP
SolveVehicleRoutingProblem
syncVRP
EditVehicleRoutingProblem
The values are case sensitive. A ValueError exception occurs when the tool_name value is not in the list of supported values or the tool_name value doesn't exist for the specified service_name value.
portal_url
The URL of the portal containing the service or a dictionary specifying connection information for a routing service on a stand-alone ArcGIS Server site.
If no value is provided, the active portal URL will be used.
The default value is None.
String
Valeur de retour
Type de données Explication
Dictionary
The GetWebToolInfo object key-value pairs.
  • isPortal—The GetWebToolInfo dictionary object keys.
  • networkDataset—Provides the information about the network dataset used by the web tool.
  • serviceLimits—Provides the limits for the web tool.
Exemple de code
GetWebToolInfo example 1
The following code sample shows how to get the maximum number of facilities supported by the Service Area utility service from your active portal.
# The following code sample shows how to get the maximum number of facilities supported by the Service Area utility
# service from your active portal.
import arcpy
# Get the active portal url
portal_url = arcpy.GetActivePortalURL()
print(f"Active portal: {portal_url}")
# Get the tool limits for the tool from the active portal
tool_info = arcpy.nax.GetWebToolInfo("asyncServiceArea", "GenerateServiceAreas")
max_facilities = tool_info["serviceLimits"]["maximumFacilities"]
print(f"Maximum facilities: {max_facilities}")
GetWebToolInfo example 2
The following code sample shows how to print the traffic support type for all the cost attributes from your network data source. The portal URL is specified explicitly.
# The following code sample shows how to print the traffic support type for all
# the cost attributes from the arcgis.com routing service.
import arcpy
    "asyncRoute", "FindRoutes", "https://www.arcgis.com/")
nd_info = tool_info["networkDataset"]
for attribute in nd_info["networkAttributes"]:
    if attribute["usageType"] == "Cost":
        print(f"{attribute['name']}: {attribute['trafficSupport']}")
GetWebToolInfo example 3
The following code sample shows how to call GetWebToolInfo for a routing service on a stand-alone ArcGIS Server site.
Learn more about how to specify a routing service info dictionary
    "asyncODCostMatrix", "GenerateOriginDestinationCostMatrix",
        "utilityUrl": f"https://mysite.mydomain.com/:6443/arcgis/rest/services/MyRouting/NetworkAnalysisUtilities/GPServer",
        "authenticationInfo": {
            "username": "my_username",
            "password": "my_password"
