LastMileDeliveryInputDataType
Résumé
Enumeration of input types for the LastMileDelivery solver.
Propriétés
| Nom | Explication | Type de données |
Orders (Lecture seule) |
The orders that will be used as input for the Last Mile Delivery analysis. These are the final customer locations where the routes deliver the packages or initial customer location where they are picking up packages for shipment. |
Object |
Depots (Lecture seule) |
The depots that will be used as input for the Last Mile Delivery analysis. A depot is a location that a vehicle departs from at the beginning of its workday and returns to at the end of the workday. |
Object |
Routes (Lecture seule) |
The routes that will be used as input for the Last Mile Delivery analysis. A route defines vehicle and driver characteristics. |
Object |
OrderSpecialties (Lecture seule) |
The specialties that are required by orders. A route can service an order only if it supports all the specialties required for that order. For example, an order may require a technician with a certain skill set or a vehicle with certain capabilities. |
Object |
RouteSpecialties (Lecture seule) |
The specialties that are supported by routes. A route can service an order only if the route supports all the specialties required for that order. For example, an order may require a technician with a certain skill set or a vehicle with certain capabilities. |
Object |
Zones (Lecture seule) |
The route zones that will be used as input for the analysis. A zone is a polygon that delineates work territories for given routes and is used to constrain routes to servicing only those orders that are within or near the specified area. |
Object |
PointBarriers (Lecture seule) |
Point barriers that temporarily restrict traversal across or add impedance to points on the network. |
Object |
LineBarriers (Lecture seule) |
Line barriers that temporarily restrict traversal across a line. |
Object |
PolygonBarriers (Lecture seule) |
Polygon barriers that temporarily restrict traversal or scale impedance on the parts of the network they cover. |
Object |
