ListDirectionsLanguages
Résumé
Returns a list of the languages in which you can generate directions for the routes you create during network analysis.
Syntaxe
ListDirectionsLanguages({network_dataset_path})
| Le paramètre | Explication | Type de données |
network_dataset_path |
This parameter is deprecated. Any value entered will be ignored. |
String |
Valeur de retour
| Type de données | Explication |
String |
A list of two- and five-character strings representing the languages available for generating directions. Learn more about directions language codes. |
Exemple de code
ListDirectionsLanguages example
Reads the available languages and stores them in a variable.
import arcpy
# Create a list of directions languages available with your ArcGIS installation
languages = arcpy.na.ListDirectionsLanguages()
