LocationAllocationOutputDataType
Résumé
Enumeration of output types for the LocationAllocation solver.
Propriétés
| Nom | Explication | Type de données |
Facilities (Lecture seule) |
Specifies the output facilities for the Location-Allocation analysis, indicating chosen, required, and competitor facilities, as well as any candidate facilities that were not chosen. |
Object |
DemandPoints (Lecture seule) |
Specifies the output demand points for the Location-Allocation analysis, indicating which points were and were not allocated to facilities. |
Object |
Lines (Lecture seule) |
Specifies the output lines connecting demand points with facilities to which they were allocated by the Location-Allocation analysis. |
Object |
