ServiceAreaOutputDataType
Résumé
Enumeration of output types for the ServiceArea solver.
Propriétés
| Nom | Explication | Type de données |
Facilities (Lecture seule) |
Specifies the output facilities for the Service Area analysis. |
Object |
Lines (Lecture seule) |
Specifies the output lines for the Service Area analysis, indicating which network edges are reachable from the facilities within the specified impedance cutoff. |
Object |
Polygons (Lecture seule) |
Specifies the output polygons for the Service Area analysis, indicating the area reachable from the facilities within the specified impedance cutoff. |
Object |
