ServiceAreaOutputType
Résumé
Enumeration of the output type to be generated for a ServiceArea analysis.
Propriétés
Nom Explication Type de données
Polygons
(Lecture seule)
The service area analysis will output polygons representing the area reachable from the facilities within the impedance cutoff.
Object
Lines
(Lecture seule)
The service area analysis will output lines representing the network edges that are reachable from the facilities within the impedance cutoff.
Object
PolygonsAndLines
(Lecture seule)
The service area analysis will output both polygons and lines.
Object
