VehicleRoutingProblemOutputDataType2
Résumé
Enumeration of output types for the VehicleRoutingProblem solver when using the VehicleRoutingProblemSchemaVersion.Two schema version.
Propriétés
| Nom | Explication | Type de données |
Orders (Lecture seule) |
The orders included in the Vehicle Routing Problem analysis, including information about the route to which the order was assigned. |
Object |
Depots (Lecture seule) |
The depots included in the Vehicle Routing Problem analysis, including information about how the depots were located on the network. |
Object |
DepotVisits (Lecture seule) |
Each instance of a depot being visited by a route, including the time of the visit and information about quantities loaded or unloaded at the depot. |
Object |
Breaks (Lecture seule) |
The breaks taken by drivers in the Vehicle Routing Problem analysis. |
Object |
Routes (Lecture seule) |
The output routes. The routes describe the paths taken through the network to visit the stops, including information about the drivers and vehicles. |
Object |
DirectionPoints (Lecture seule) |
This is the output turn-by-turn directions for the routes calculated in the analysis, represented as point locations along the routes where specific direction events or maneuvers occur. |
Object |
DirectionLines (Lecture seule) |
This is the output route lines calculated in the analysis sliced to represent each route segment between |
Object |
