WasteCollectionResult
Résumé
An object containing the results of a waste collection analysis that can be used to access outputs and solver messages.
Discussion
Instances of this class cannot be created directly. Instead, they are returned by the solve method of the WasteCollection class.
Learn more about how to use the result object to access and work with the analysis outputs
Propriétés
| Nom | Explication | Type de données |
isPartialSolution (Lecture seule) |
Returns |
Boolean |
solveSucceeded (Lecture seule) |
Returns |
Boolean |
spatialReference (Lecture seule) |
Returns the spatial reference of the output features. For example, feature classes created using the |
SpatialReference |
Méthodes
count(output_type)
Returns the number of rows for an output type.
output_type |
The type of output features to count. Set this parameter using the |
Object |
Valeur de retour
| Type de données | Explication |
Integer |
The number of rows. |
export(output_type, output_features)
Exports the analysis results to a feature class or table.
The output features will be created in the spatial reference of the network dataset used for the analysis. If the arcpy.env.outputCoordinateSystem environment is set, the output features will be created with the specified coordinate system instead.
output_type |
The type of output to export. Set this parameter using the |
Object |
output_features |
The catalog path to the output feature class or table that will contain the exported features. |
String |
extent({output_type})
Returns the extent of the analysis output.
The method returns a RuntimeError exception if the analysis solve failed.
output_type (Facultatif) |
The type of output features for which to get the extent. Set this parameter using the If you do not specify a value, or you specify a value of |
Object |
Valeur de retour
Extent |
An |
fieldNames(output_type)
Returns a list of field names supported by a specified output type.
output_type |
The type of output for which to return a list of field names. Set this parameter using the |
Object |
Valeur de retour
String |
A list of field names supported by the specified output type. |
saveAsLayerFile(file_name)
Saves the analysis result and settings to a layer package. The layer package can be opened in ArcGIS Pro as a record of the analysis settings or to visualize the results.
file_name |
The catalog path of the output layer package ( Remarque :Layer files with an |
String |
searchCursor(output_type, field_names[field_names,...], {where_clause})
Establishes a search cursor on the specified output type. This cursor can be used to read rows directly from the output.
output_type |
The type of output that will be read. Set this parameter using the |
Object |
field_names[field_names,...] |
A list of field names of the output type whose values will be returned by the cursor. You can get the names of the fields supported by an output type using the Learn more about the fields included in each output type In addition to regular fields, you can also access the geometry of the output using one of the following geometry tokens:
The |
String |
where_clause (Facultatif) |
An optional expression that limits the records returned. For more information on WHERE clauses and SQL statements, see SQL reference for query expressions used in ArcGIS. The default value is None. |
String |
Valeur de retour
Object |
A |
solverMessages(severity)
Get error, warning, and informational messages returned by the solver.
severity |
The type of messages to be returned. The parameter should be specified using the |
Object |
Valeur de retour
List |
The messages are returned as a list of lists. The inner list contains two values; the first is a number representing the message code, and the second value is the message text. An example of a list of messages returned from a failed origin destination cost matrix analysis.
