ColorspaceConversion
Résumé
Converts the color model of a three-band unsigned 8-bit image from the hue, saturation, and value (HSV) to red, green, and blue (RGB) or vice versa.
Discussion
For more information about how this function works, see the Color Model Conversion raster function.
The referenced raster dataset for the raster object is temporary. To make it permanent, you can call the raster object's save method.
Syntaxe
ColorspaceConversion(raster, {conversion_type})
Le paramètre Explication Type de données
raster
An unsigned 8-bit pixel type input raster.
Raster
conversion_type
The color conversion type to perform.
  • rgb_to_hsv—RGB to HSV
  • hsv_to_rgb—HSV to RGB
The default value is rgb_to_hsv.
String
Valeur de retour
Type de données Explication
Raster
The output raster.
Exemple de code
ColorspaceConversion example 1
This example applies the Colorspace Conversion function to the input raster.
from arcpy.sa import *
out_hsv_3bands = ColorspaceConversion("slope_rgb_3bands.tif", "rgb_to_hsv")
out_hsv_3bands.save("C:/arcpyExamples/outputs/slope_hsv_3bands.tif")
ColorspaceConversion example 2
# Import system modules
import arcpy
# Set the analysis environments
arcpy.env.workspace = "C:/arcpyExamples/data"
# Set the local variables
# the pixeltype of the input raster must be unsigned 8-bit, otherwise,
# the function would fail
in_raster = "slope_rgb_3bands.tif"
# Run ColorspaceConversion function
slope_hsv_3bands = ColorspaceConversion(in_raster, "rgb_to_hsv")
# Save the output
slope_hsv_3bands.save("C:/arcpyExamples/outputs/slope_hsv_3bands.tif")
