LinearUnmixing
Résumé
Performs subpixel classification and calculates the fractional abundance of land-cover types for individual pixels.
Discussion
For more information about how this function works, see the Linear Spectral Unmixing raster function.
The referenced raster dataset for the raster object is temporary. To make it permanent, you can call the raster object's save method.
Syntaxe
LinearUnmixing(in_raster, in_spectral_profile_file, {value_option})
Le paramètre Explication Type de données
in_raster
The input raster.
Raster
The path to the spectral profile for the various land cover classes.
This can be provided as a polygon feature class, a classifier definition file (.ecd) generated from the Train Maximum Likelihood Classifier tool, or a JSON file (.json) that contains the class spectral profiles.
String
value_option
Specifies how the output pixel values will be defined.
  • SUM_TO_ONE—Class values for each pixel will be provided in decimal format with the sum of all classes equal to 1; for example, Class1 = 0.16; Class2 = 0.24; Class3 = 0.60.
  • NON_NEGATIVE—There will be no negative output values.
Both options can be specified by delimiting with a semicolon: "SUM_TO_ONE;NON_NEGATIVE".
String
Valeur de retour
Type de données Explication
Raster
The output raster.
Exemple de code
LinearUnmixing example
This example resolves the fractional class values for each pixel in the multispectral raster.
from arcpy.sa import *
out_linearunmixing_raster = LinearUnmixing(
    "Landsat8.tif","C:/arcpyExamples/data/training_feature.ecd")
out_linearunmixing_raster.save(
    "C:/arcpyexamples/outputs/linearunmix_output.tif")
# Import system modules
import arcpy
# Set the analysis environments
arcpy.env.workspace = "C:/arcpyExamples/data"
# Set the local variables
in_raster = "Landsat_8.tif"
in_spectral_profile = "C:/data/training_features.ecd"
value_options = "SUM_TO_ONE;NON_NEGATIVE"
# Apply LinearSpectralUnmixing function
unmixing_outputs = LinearUnmixing(in_raster, in_spectral_profile, value_options)
# Save the output
unmixing_outputs.save("C:/arcpyExamples/outputs/unmixing_results.tif")
