Supported formats with the Data Interoperability extension
Disponible avec une licence Data Interoperability.
All formats supported by the Data Interoperability extension are uniquely identified by an uppercase alphanumeric string. Some formats support reading and writing, and others support only reading or writing exclusively. Some formats are only available for download on the FME HUB.
For more detailed information about these specific FME Reader and Writer formats, you can access the documentation through the Data Interoperability Workbench application dialog boxes using the help button.
Supported formats
| Short Name | Description | Reader/Writer | Available on FME Hub |
| 12DXML | 12d Model | Reader/Writer | |
| 3DS | Autodesk 3ds | Reader/Writer | |
| ACAD | Autodesk AutoCAD DWG/DXF | Reader/Writer | |
| ADAC | Australian Asset Design and As Constructed (ADAC) | Reader/Writer | |
| ADRG | ADRG (ARC Digitized Raster Graphics) | Reader | |
| AIS | NMEA Automatic Identification System (AIS) | Reader | |
| AIXM | Aeronautical Information Exchange Model XML version 4.5 (AIXM 4.5) | Reader/Writer | |
| AIXM5 | Aeronautical Information Exchange Model GML version 5.1 (AIXM 5.1) | Reader/Writer | |
| AIXM5X | Aeronautical Information Exchange Model GML version 5.x (AIXM 5.x) | Reader | |
| AMAZON_MYSQL | Amazon Aurora (MySQL-Compatible) | Reader/Writer | |
| AML | S-57 Additional Military Layers (AML) | Reader | |
| APACHE_HIVE | Apache Hive (Hadoop) | Reader | |
| ARCGEN | Esri ArcInfo Generate | Reader/Writer | |
| ARCGISFEATURES | Esri ArcGIS Server Feature Service | Reader/Writer | |
| ARCGISMAP | Esri ArcGIS Map Document | Reader | |
| ARCGISONLINEFEATURES | Esri ArcGIS Online (AGOL) Feature Services | Reader/Writer | |
| ARCGISPORTALFEATURES | Esri ArcGIS Portal Feature Services | Reader/Writer | |
| ARCGIS_LAYER | Esri ArcGIS Layer | Reader | |
| ARCINFO | Esri ArcInfo Coverage | Reader/Writer | |
| ARCVIEWGRID | Esri ArcGIS Binary Grid (AIG) | Reader | |
| ASRP | ARC Standard Raster Product (ASRP) | Reader | |
| AUTOMATIONS | FME Server Automations | Writer | |
| AZURE_TABLE | Microsoft Windows Azure Table | Reader/Writer | |
| BAG | Bathymetric Attributed Grid | Reader/Writer | |
| BASISU | Basic Universal | Reader/Writer | |
| BCF | BIM Collaboration Format (BCF) | Reader/Writer | |
| BMP | Microsoft Bitmap (BMP) | Reader/Writer | |
| BSB | Maptech BSB Nautical Chart | Reader | |
| CADRG | CADRG (Compressed ARC Digitized Raster Graphics) | Reader/Writer | |
| CALS | Continuous Acquisition and Life-cycle Support (CALS) | Reader/Writer | |
| CARTO | CARTO | Reader/Writer | |
| CAT | Column Aligned Text (CAT) | Reader | |
| CDED | Canadian Digital Elevation Data (CDED) | Reader/Writer | |
| CESIUM3DPC | Cesium 3D Point Cloud | Reader/Writer | |
| CESIUM3DTILES | Cesium 3D Tiles | Writer | |
| CGDEF | ComGraphix Data Exchange Format (CGDEF) | Reader/Writer | |
| CH.EHI.FME.MAIN | Swiss INTERLIS (ili2fme) | Reader/Writer | |
| CIB | CIB (Controlled Image Base) | Reader/Writer | |
| CITYGML | OGC CityGML | Reader/Writer | |
| CITYGML3 | OGC CityGML 3 (Tech Preview) | Reader | |
| CITYJSON | CityJSON | Reader/Writer | |
| CIVIL3D | Autodesk AutoCAD Civil 3D | Reader | |
| COG | CoG (Cloud-Optimized GeoTIFF) | Reader/Writer | |
| COLLADA | COLLADA (Collaborative Design Activity) | Reader/Writer | |
| COPC | COPC (Cloud Optimized Point Cloud) | Reader/Writer | |
| CSV2 | Comma-Separated Value (CSV) | Reader/Writer | |
| CUZK_GML | CUZK GML (Czech Republic) | Reader | |
| DATABRICKS_JDBC | Databricks (JDBC) | Reader | |
| DATAFILE | Data File | Reader/Writer | |
| DB2 | IBM Db2 Nonspatial | Reader/Writer | |
| DB2SPATIAL | IBM Db2 Spatial | Reader/Writer | |
| DB2SPATIAL_DASHDB | IBM Db2 Warehouse on Cloud Spatial | Reader/Writer | |
| DB2_DASHDB | IBM Db2 Warehouse on Cloud Non-Spatial | Reader/Writer | |
| DB2_JDBC | IBM Db2 (JDBC) | Reader/Writer | |
| DB2_JDBC_NONSPATIAL | IBM Db2 Non-Spatial (JDBC) | Reader/Writer | |
| DBASE | dBASE (DBF) | Reader/Writer | |
| DDS | Microsoft DirectDraw Surface (DDS) | Reader/Writer | |
| DELORME_GPL | DeLorme GPS Track Logs (GPL) Reader | Reader | |
| DELTALAKE | Delta Lake | Reader | |
| DENODO | Denodo | Reader | |
| DGNV8 | Bentley MicroStation Design (V8) | Reader/Writer | |
| DICOM FILE | Digital Imaging and Communications in Medicine | Reader/Writer | |
| DICOM_DIR | Digital Imaging and Communications in Medicine | Reader | |
| DIRECTX | Microsoft DirectX | Reader/Writer | |
| DLG | Digital Line Graph (DLG) | Reader | |
| DMDF | Digital Map Data Format (DMDF) | Reader | |
| DNF | UK OS MasterMap Topography Layer (Non-XSD Driven, GML v2.1.2 Only) | Reader | |
| DOCUMENTDB | Microsoft Azure Cosmos DB | Reader/Writer | |
| DSFL | Danish DSFL | Reader | |
| DSFLW2 | Danish DSFL Writer V.2 | Writer | |
| DTED | DTED (Digital Terrain Elevation Data) | Reader/Writer | |
| DUCKDB | DuckDB | Reader | |
| DWF | Autodesk AutoCAD DWF | Reader/Writer | |
| DWML | Digital Weather Markup Language | Reader | |
| DYNAMODB | Amazon DynamoDB | Reader/Writer | |
| E00 | Esri ArcInfo Export (E00) | Reader/Writer | |
| E57 | ASTM E57 | Reader/Writer | |
| ELASTICSEARCH | Elastic Elasticsearch v6.8 and earlier (deprecated) | Reader/Writer | |
| ELASTICSEARCH_CLUSTER | Elastic Elasticsearch | Reader/Writer | |
| ENVIHDR | ITT ENVI .HDR RAW Raster | Reader/Writer | |
| EPA_GDXML | U.S. Environmental Protection Agency (EPA) Geospatial Data | Reader | |
| EPS | Encapsulated PostScript (EPS) | Writer | |
| EPT | Entwine Point Tile (EPT) | Reader | |
| ERDAS | ERDAS IMAGINE | Reader/Writer | |
| ERDASRAW | ERDAS RAW | Reader/Writer | |
| ERS | ER Mapper ERS | Reader/Writer | |
| ESF | BC MoF Electronic Submission Framework (ESF) | Reader/Writer | |
| ESF_XSD | BC MoF Electronic Submission Framework (XSD- Driven) | Reader/Writer | |
| ESRIASCIIGRID | Esri ASCII Grid | Reader/Writer | |
| ESRIHDR | Esri.HDR RAW Raster | Reader/Writer | |
| ESRIJSON | Esri_JSON (Esri JavaScript Object Notation) | Reader/Writer | |
| ESRIMSD | Esri Mapping Specification for CAD (MSC) | Reader/Writer | |
| ESRI_KNOWLEDGE_GRAPH | Esri Knowledge | Reader/Writer | |
| ESRI_MOBILE_GEODATABASE | Esri Mobile Geodatabase | Reader/Writer | |
| FABRIC_WAREHOUSE_JDBC | Microsoft Fabric (Data Warehouse) | Reader/Writer | |
| FACET | Facet XDR | Reader/Writer | |
| FBX | Autodesk FBX | Reader/Writer | |
| FFS | FME Feature Store (FFS) | Reader/Writer | |
| FILECOPY | File Copy | Writer | |
| FILEGDB | Esri Geodatabase (File Geodatabase API) | Reader/Writer | |
| FITS | FITS (Flexible Image Transport System) | Reader/Writer | |
| FLATGEOBUF | FlatGeobuf | Reader/Writer | |
| FM0 | Intergraph GeoMedia Access Warehouse | Reader | |
| FM0_SQL | Intergraph GeoMedia SQL Server Warehouse | Reader/Writer | |
| FME_AR | FME Augmented Reality (FME AR) | Writer | |
| FMW | FME Workspace (FMW) | Reader | |
| GARMIN_GDB | Garmin GDB | Reader/Writer | |
| GARMIN_GPI | Garmin GPI | Reader/Writer | |
| GARMIN_POI | Garmin POI | Reader/Writer | |
| GDAL_ACE2 | ACE2 (from GDAL Format) | Reader | |
| GDAL_AIRSAR | NASA JPL Airborne Synthetic Aperture Radar (AIRSAR) Polarimetric (from GDAL Format) | Reader | |
| GDAL_BLX | Magellan BLX Topographical (from GDAL Format) | Reader | |
| GDAL_BT | Virtual Terrain Project Binary Terrain Format (from GDAL Format) | Reader | |
| GDAL_COASP | CEOS (Spot for instance) (from GDAL Format) | Reader | |
| GDAL_COSAR | TerraSAR-X Complex SAR (Synthetic Aperture Radar) (from GDAL Format) | Reader | |
| GDAL_CPG | Convair PolGASP (from GDAL Format) | Reader | |
| GDAL_CTG | USGS Land Use and Land Cover (LULC) Composite Theme Grid (from GDAL Format) | Reader | |
| GDAL_DOQ1 | First Generation USGS Digital Ortho Quad (DOQ) (from GDAL Format) | Reader | |
| GDAL_DOQ2 | New Labelled USGS Digital Ortho Quad (DOQ) (from GDAL Format) | Reader | |
| GDAL_ECRGTOC | Enhanced Compressed Raster Graphic (ECRG) Table Of Contents (from GDAL Format) | Reader | |
| GDAL_ELAS | NASA Earth Resources Laboratory Applications Software (ELAS) (from GDAL Format) | Reader | |
| GDAL_FAST | Earth Observation Satellite (EOSAT) Company FAST (from GDAL Format) | Reader | |
| GDAL_GENBIN | Generic Binary (.hdr Labelled) (from GDAL Format) | Reader | |
| GDAL_GENERIC_RASTER | GDAL Generic Raster | Reader | |
| GDAL_GFF | Sandia National Laboratories GSat (from GDAL Format) | Reader | |
| GDAL_GSAG | Golden Software ASCII Grid (from GDAL Format) | Reader | |
| GDAL_GXF | Grid eXchange File (GXF) (from GDAL Format) | Reader | |
| GDAL_IRIS | Interactive Radar Information System (IRIS) (from GDAL Format) | Reader | |
| GDAL_ISIS2 | USGS Astrogeology International Satellites for Ionospheric Studies (ISIS) cube (Version 2) (from GDAL Format) | Reader | |
| GDAL_ISIS3 | USGS Astrogeology International Satellites for Ionospheric Studies (ISIS) cube (Version 3) (from GDAL Format) | Reader | |
| GDAL_JAXAPALSAR | Japanese Aerospace eXploration Agency (JAXA) Phased Array Type L-band Synthetic Aperture Radar (PALSAR) Product Reader (Level 1.1/1.5) (from GDAL Format) | Reader | |
| GDAL_JDEM | Japanese Digital Elevation Model (DEM) (from GDAL Format) | Reader | |
| GDAL_KRO | KRO (from GDAL Format) | Reader | |
| GDAL_L1B | NOAA (National Oceanic and Atmospheric Administration) Polar Orbiter Level 1b Data Set - Advanced Very High Resolution Radiometer (AVHRR) (from GDAL Format) | Reader | |
| GDAL_LAN | Erdas 7.x .LAN and .GIS (from GDAL Format) | Reader | |
| GDAL_LCP | FARSITE v.4 Landscape (from GDAL Format) | Reader | |
| GDAL_LEVELLER | Daylon Leveller Heightfield (from GDAL Format) | Reader | |
| GDAL_LOSLAS | North America Datum Conversion Utility (NADCON) .los/.las Datum Grid Shift (from GDAL Format) | Reader | |
| GDAL_MAP | OziExplorer .MAP (from GDAL Format) | Reader | |
| GDAL_MFF | Vexcel Multi-File Format (MFF) (from GDAL Format) | Reader | |
| GDAL_MFF2 | Vexcel Multi-File Format (MFF) 2 - Hierarchical Key Value (HKV) (from GDAL Format) | Reader | |
| GDAL_NDF | National Land Archive Production System (NLAPS) (from GDAL Format) | Reader | |
| GDAL_NGSGEOID | NOAA (National Oceanic and Atmospheric Administration) National Geodetic Survey (NGS) Geoid Height Grids (from GDAL Format) | Reader | |
| GDAL_OZI | OziExplorer OZI OZF2/OZFX3 (from GDAL Format) | Reader | |
| GDAL_PAUX | PCI .aux Labelled (from GDAL Format) | Reader | |
| GDAL_PCRASTER | PCRaster (from GDAL Format) | Reader | |
| GDAL_PDS | NASA Planetary Data System (from GDAL Format) | Reader | |
| GDAL_PNM | Netpbm (from GDAL Format) | Reader | |
| GDAL_RMF | Raster Matrix Format (from GDAL Format) | Reader | |
| GDAL_ROI_PAC | NASA JPL (Jet Propulsion Laboratory) Repeat Orbit Interferometry Package (ROI PAC) Raster (from GDAL Format) | Reader | |
| GDAL_RS2 | RadarSat2 XML (from GDAL Format) | Reader | |
| GDAL_SAGA | System for Automated Geoscientific Analysis (SAGA GIS) Binary (from GDAL Format) | Reader | |
| GDAL_SAR_CEOS | Synthetic Aperture Radar (SAR) CEOS (from GDAL Format) | Reader | |
| GDAL_SNODAS | Snow Data Assimilation System (from GDAL Format) | Reader | |
| GDAL_TERRAGEN | Terragen Heightfield (from GDAL Format) | Reader | |
| GDAL_TIL | EarthWatch/DigitalGlobe (from GDAL Format) | Reader | |
| GDAL_TSX | TerraSAR-X (from GDAL Format) | Reader | |
| GDAL_VICAR | Video Image Communication And Retrieval (from GDAL Format) | Reader | |
| GDMS | Geographic Data Management System (GDMS) | Reader | |
| GENAMAP | Genasys GenaMap | Reader | |
| GENERIC | Generic (Any Format) | Reader/Writer | |
| GEODATABASE_FILE | Esri Geodatabase (File Geodatabase ArcObjects) | Reader/Writer | |
| GEODATABASE_FILE_MOSAIC_DATASET | Esri Geodatabase (File Geodatabase Mosaic Dataset) | Writer | |
| GEODATABASE_FILE_RASTER_CATALOG | Esri Geodatabase (File Geodatabase Raster Catalog) | Reader | |
| GEODATABASE_FILE_RASTER_DATASET | Esri Geodatabase (File Geodatabase Raster Dataset) | Reader/Writer | |
| GEODATABASE_SDE | Esri Geodatabase (ArcSDE Geodatabase) | Reader/Writer | |
| GEODATABASE_SDE_MOSAIC_DATASET | Esri Geodatabase (ArcSDE Geodatabase Mosaic Dataset) | Writer | |
| GEODATABASE_SDE_RASTER_CATALOG | Esri Geodatabase (ArcSDE Geodatabase Raster Catalog) | Reader | |
| GEODATABASE_SDE_RASTER_DATASET | Esri Geodatabase (ArcSDE Geodatabase Raster Dataset) | Reader/Writer | |
| GEODATABASE_XML | Esri Geodatabase (XML Workspace Document) | Reader | |
| GEOHASH | Geohash | Reader | |
| GEOJSON | Geographic JavaScript Object Notation (GeoJSON) | Reader/Writer | |
| GEONET | NGA GEOnet Names Server | Reader | |
| GEOPACKAGE_RASTER | OGC GeoPackage Tiles | Reader/Writer | |
| GEOPARQUET | Apache GeoParquet | Reader/Writer | |
| GEORSS | GeoRSS/RSS Feed | Reader/Writer | |
| GEOTIFF | Georeferenced Tagged Image File Format (GeoTIFF) | Reader/Writer | |
| GG | Bentley MicroStation GeoGraphics | Reader/Writer | |
| GIF | GIF Rasterizer | Writer | |
| GIFRASTER | GIF (Graphic Interchange Format) | Reader/Writer | |
| GLTF | glTF (GL Transmission Format) | Writer | |
| GML | GML (Geography Markup Language) | Reader/Writer | |
| GML2 | GML v2.1.2 | Writer | |
| GML212 | GML v2.1.2 | Reader | |
| GMLSF | GML SF-0 (Geography Markup Language Simple Features Level SF-0 Profile) | Reader/Writer | |
| GOOGLE_MYSQL | Google Cloud SQL (MySQL-Compatible) | Reader/Writer | |
| GPXX | GPS eXchange Format (GPX) | Reader/Writer | |
| GRD | PenMetrics GRD | Reader/Writer | |
| GRIB | World Meteorological Organization GRIB (GRIdded Binary) | Reader | |
| GTFS | General Transit Feed Specification (GTFS) | Reader/Writer | |
| GUESS_FROM_EXTENSION | Guess format name from extension | Reader | |
| HDF4_ASTER | Hierarchical Data Format 4 (HDF4) ASTER | Reader | |
| HDF4_HYPERION | Hierarchical Data Format 4 (HDF4) Hyperion | Reader | |
| HEIF | HEIF (High Efficiency Image File Format) | Reader | |
| HERE_VENUE_MAP | HERE Venue Map (GML) | Reader/Writer | |
| HTML | HTML | Writer | |
| HTMLTABLE | HTML Table | Reader | |
| HXL_CSV | HXL (Humanitarian Exchange Language) for CSV | Reader | |
| HYD93 | NGDC Hydrographic Surveys Data Exchange (HYD93) | Reader/Writer | |
| HYPACKBRD | Hypack Border | Reader/Writer | |
| I2KGML | Swedish I2K/G2K (Interface 2000 GML) | Reader/Writer | |
| I3S | Esri Indexed 3D Scene Layer | Writer | |
| IDRISI | IDRISI Vector Format | Reader/Writer | |
| IDRISI_RASTER | IDRISI Raster Format | Reader/Writer | |
| IEPS | Adobe Illustrator EPS | Writer | |
| IFC | Industry Foundation Class STEP/XML Files (IFC) | Reader/Writer | |
| IFC_API | Industry Foundation Classes (IFC) (Tech Preview) | Reader | |
| IFF | 1Spatial Internal Feature Format (IFF) | Reader/Writer | |
| IGDS | Bentley MicroStation Design (V7) | Reader/Writer | |
| IMDF | Indoor Mapping Data Format (IMDF) | Reader/Writer | |
| IMX | Autodesk IMX (FDO) | Writer | |
| INDOORGML | Indoor GML | Reader/Writer | |
| INFORMIX_JDBC | IBM Informix (JDBC) | Reader/Writer | |
| INFX | IBM Informix Non-Spatial | Reader/Writer | |
| INFXSPATIAL | IBM Informix Spatial | Reader/Writer | |
| INSPIRE | INSPIRE GML | Reader/Writer | |
| ISCE | Interferometric synthetic aperture radar Scientific Computing Environment (ISCE) | Reader/Writer | |
| ISO8211 | ISO8211 | Reader | |
| IUF | Land Victoria Incremental Update Format (IUF) | Reader | |
| JDBC | Java Database Connectivity (JDBC) | Reader/Writer | |
| JOBXML | Trimble JobXML | Reader | |
| JPEG | Joint Photographic Experts Group (JPEG) | Reader/Writer | |
| JSON | JavaScript Object Notation (JSON) | Reader/Writer | |
| KF85 | Swedish KF85 | Reader/Writer | |
| KOMMUNGML | KommunGML (Sweden) | Reader | |
| KUNTAGML | KuntaGML (Finland) | Reader | |
| LANDONLINE | Landonline (Land Information New Zealand Cadastre Survey Data Exchange Format based on LandXML) | Reader | |
| LANDSAT8 | Landsat-8 | Reader | |
| LANDSAT8AWS | Landsat-8 on AWS | Reader | |
| LANDXML | LandXML | Reader | |
| LAS | ASPRS Lidar Data Exchange Format (LAS) | Reader/Writer | |
| LOCATION_JSON | Location JSON | Reader | |
| MASIK | Swedish MASIK | Reader/Writer | |
| MBTILES | Mapbox MBTiles | Reader/Writer | |
| MBTILES_MVT | Mapbox MBTiles Vector Tiles (MVT) | Reader/Writer | |
| MCF | STAR-APIC Mercator MCF | Reader/Writer | |
| MDB_ADO | Microsoft Access | Reader/Writer | |
| MGE | Intergraph MGE | Reader/Writer | |
| MIF | MapInfo MIF/MID | Reader/Writer | |
| MINECRAFT | Mojang Minecraft | Reader/Writer | |
| MITAB | MapInfo TAB (MITAB) | Reader/Writer | |
| MONGODB3 | MongoDB | Reader/Writer | |
| MRF | Meta Raster Format (MRF) | Reader/Writer | |
| MRF_NATIVE | Precisely Multi-Resolution Raster (MRR) | Reader/Writer | |
| MRSID | Extensis MrSID | Reader | |
| MSACCESS_JDBC_2 | Microsoft Access (JDBC) | Reader/Writer | |
| MSSQL_JDBC_AZURE | Microsoft Azure Microsoft Azure SQL Database (JDBC MSSQL) | Reader/Writer | |
| MSWORD | Microsoft Word | Writer | |
| MTKGML | NLSF Topographic GML (MTKGML) | Reader | |
| MVT | Mapbox Vector Tile (MVT) | Reader | |
| MVT_TILESET | Mapbox Vector Tile (MVT) Tileset | Reader/Writer | |
| MYSQL | MariaDB (MySQL compatible) Spatial | Reader/Writer | |
| MYSQL_AURORA_NONSPATIAL | Amazon Aurora Non-Spatial | Reader/Writer | |
| MYSQL_AURORA_SPATIAL | Amazon Aurora Spatial | Reader/Writer | |
| MYSQL_DATABASE | MariaDB/SkySQL (MySQL-compatible) | Reader/Writer | |
| MYSQL_DB | MariaDB (MySQL compatible) Non-Spatial | Reader/Writer | |
| MYSQL_GOOGLE | Google Cloud SQL Spatial | Reader/Writer | |
| MYSQL_GOOGLE_DB | Google Cloud SQL Non-Spatial | Reader/Writer | |
| NAS | German AAA GML Exchange Format (NAS) | Reader | |
| NDGEOJSON | NDGeoJSON (Newline Delimited GeoJSON) | Reader/Writer | |
| NDJSON | NDJSON (Newline Delimited JSON) | Reader/Writer | |
| NEN3610 | NEN 3610 (GML) | Reader | |
| NETCDF | NetCDF (Network Common Data Form) | Reader/Writer | |
| NGRID | MapInfo Vertical Mapper Grid (NGrid) | Reader/Writer | |
| NIFTI | NITFI (Neuroimaging Informatics Technology Initiative) | Reader/Writer | |
| NITF | National Imagery Transmission Format | Reader/Writer (JITC uncertified) | |
| NMEA_GPS | NMEA GPS | Reader | |
| NTF | OS (GB) NTF | Reader | |
| NULL | NULL (Nothing) | Reader/Writer | |
| OBJ | Wavefront OBJ | Reader/Writer | |
| ODATA | OData | Reader | |
| ODBC2 | ODBC 3.x | Reader/Writer | |
| OGCAPI_FEATURES | OGC API - Features (WFS 3.0) | Reader | |
| OGCGEOPACKAGE | OGC GeoPackage | Reader/Writer | |
| OGCKML | Google Earth KML | Reader/Writer | |
| OGC_CSW | OGC CSW - (Catalogue Service for the Web) | Reader/Writer | |
| OGDI | Microsoft OGDI Data Lab | Reader/Writer | |
| OGEOSMS | OGC Open GeoSMS | Reader | |
| OPENFILEGDB | Esri Geodatabase (OpenFile Geodb) | Reader/Writer | |
| OPENFLIGHT | Presagis .flt (OPENFLIGHT) | Reader/Writer | |
| OPENJPEG | OpenJPEG JPEG 2000 | Reader/Writer | |
| ORACLEPOINTCLOUD | Oracle Spatial Point Cloud | Reader/Writer | |
| ORACLERASTER | Oracle Spatial GeoRaster | Reader/Writer | |
| ORACLE_AUTONOMOUS | Oracle Autonomous | Reader/Writer | |
| ORACLE_DATABASE | Oracle Database | Reader/Writer | |
| ORACLE_RELATIONAL | Oracle Spatial Relational | Reader/Writer | |
| OSG | OpenSceneGraphic OSGB/OSGT | Reader/Writer | |
| OSM | OpenStreetMap (OSM) XML | Reader/Writer | |
| OSMASTERMAP_WATER_NETWORK_GML | UK OS MasterMap Water Network (GML) | Reader/Writer | |
| OSMPBF | OpenStreetMap (OSM) Protocolbuffer Binary Format (PBF) | Reader | |
| OSVECTORMAPDISTRICT | OS VectorMap District | Reader | |
| OSVECTORMAPLOCAL | OS VectorMap Local | Reader | |
| OS_MASTERMAP_GREENSPACE_GML | UK OS MasterMap Greenspace Layer (GML) | Reader/Writer | |
| OS_MASTERMAP_HIGHWAYS_NETWORK_GML | UK OS MasterMap Highways Network (GML) | Reader/Writer | |
| OS_MASTERMAP_SITES_GML | UK OS MasterMap Sites Layer (GML) | Reader/Writer | |
| OS_MASTERMAP_TOPOGRAPHY_GML | UK OS MasterMap Topograpy Layer (GML) | Reader/Writer | |
| P190 | PGP P1/90 Post Plot Positioning Data | Reader/Writer | |
| PARQUET | Apache Parquet | Reader/Writer | |
| PARQUET_DIR | Apache Parquet (Partitioned) | Reader | |
| PATH | Directory or File Pathnames | Reader | |
| PCARCINFO | Esri PC ArcInfo Coverage | Reader | |
| PCD | Point Cloud Data (PCD) | Reader/Writer | |
| PCIDSK | PCI Geomatics Database File (PCIDSK) | Reader/Writer | |
| Adobe 3D PDF | Writer | ||
| PDF2D | Adobe Geospatial PDF | Reader/Writer | |
| PERSONAL_GEODATABASE | Esri Geodatabase (Personal Geodb) | Reader | |
| PLANETBASEMAPS | Planet Basemaps (Tech Preview) | Reader | |
| PLANETDATA | Planet Data | Reader | |
| PMTILES | PMTiles | Reader/Writer | |
| PNG | PNG Rasterizer | Writer | |
| PNGRASTER | Portable Network Graphic (PNG) | Reader/Writer | |
| POINTCLOUDXYZ | Point Cloud XYZ | Reader/Writer | |
| POSTGIS | PostGIS | Reader/Writer | |
| POSTGISRASTER | PostGIS Raster | Reader/Writer | |
| POSTGRES | PostgreSQL | Reader/Writer | |
| POWERPOINT | Microsoft PowerPoint | Writer | |
| PROTOBUF | Protocol Buffers | Reader/Writer | |
| PRC | Adobe Product Representation Compact (PRC) | Writer | |
| QLF | CITS Data Transfer Format (QLF) | Reader/Writer | |
| QLIKCONNECTOR | Qlik Connector | Reader | |
| QUBICLEBINARY | Qubicle Binary Voxel File (QB) | Reader | |
| QVX | Qlik data eXchange | Writer | |
| RADARSAT2 | RADARSAT-2 XML | Reader | |
| RDATA | R Statistical Data (RDATA) Non-Spatial | Reader/Writer | |
| RDATARASTER | R Statistical Data (RDATA) Array as Raster | Reader/Writer | |
| RDB | RIEGL Laser Scan Database (RDB) | Reader | |
| RDB_PROJECT | RIEGL RDB Project | Reader | |
| REDSHIFT | Amazon Redshift | Reader/Writer | |
| REDSHIFT_SPATIAL | Amazon Redshift (Spatial) | Reader/Writer | |
| REGIS | Regional Geographic Information System (REGIS) | Reader/Writer | |
| REVIT | IFC with Data Views | Reader | |
| REVITNATIVE | Autodesk Revit | Reader/Writer | |
| RRASTER | R Statistical Raster Data (RRASTER) .grd | Reader/Writer | |
| S57 | S-57 (ENC) Hydrographic Data | Reader | |
| SAFE SOCRATA.SOCRATA2 | Socrata | Reader/Writer | YES |
| SAFE SOCRATA.SOCRATA2 | Tyler Data & Insight | Reader/Writer | YES |
| SAFE.AIRTABLE.AIRTABLE | Airtable | Reader/Writer | YES |
| SAFE.CKAN.CKANDATASTORE | CKAN DataStore | Reader/Writer | YES |
| SAFE.DOCUMENTPDF.DOCUMENTPDF | Document PDF | Writer | YES |
| SAFE.ESRI-AGOL.ARCGISFEATURESERVICE | Esri ArcGIS Feature Service | Reader/Writer | YES |
| SAFE.GOOGLE-SHEETS.gOOGLESHEETS4 | Google Sheets v4 | Reader/Writer | YES |
| SAFE.NEO4J.NEO4J | nEO4J | Reader | YES |
| SAFE.STAC.STAC.ASSET | STAC Asset | Reader | YES |
| SAFE.STAC.STAC.METADATA | STAC Metadata | Reader | YES |
| SAFE.UNFOLDED.UNFOLDEDDATA | Foursquare studio Data | Reader/Writer | YES |
| SAIF | Spatial Archive and Interchange Format (SAIF) | Reader | |
| SALESFORCE | Salesforce | Reader/Writer | |
| SAP_HANA__CLOUD | SAP Hana Cloud | Reader | |
| SAP_HANA | SAP HANA | Reader/Writer | |
| SAP_SYBASE_ASE | SAP Sybase ASE | Reader/Writer | |
| SAS | Statistical Analysis System (SAS) | Reader/Writer | |
| SAV | IBM PASW (SPSS) .sav | Reader/Writer | |
| SCHEMA | Schema (Any Format) | Reader | |
| SCHEMA_FROM_TABLE | Schema (From Table) | Reader | |
| SDF3 | Autodesk MapGuide Enterprise SDF | Reader/Writer | |
| SDL | Autodesk MapGuide SDL | Reader/Writer | |
| SDTS | Spatial Data Transfer Standard (SDTS) | Reader | |
| SEABEDML | SeabedML (GML) | Reader/Writer | |
| SEG-P1 | SEG-P1 | Reader | |
| SEGY | SEG-Y | Reader/Writer | |
| SENTINEL1 | Sentinel-1 SAR SAFE | Reader | |
| SENTINEL2 | Sentinel-2 MSI SAFE | Reader | |
| SENTINEL2AWS | Sentinel-2 on AWS | Reader | |
| SGI | SGI IMAGE | Reader/Writer | |
| SHAPEFILE | Esri Shape | Reader/Writer | |
| SHAREPOINT | Microsoft SharePoint | Reader/Writer | |
| SIMPLECUSTOMFORMAT | SimpleCustomFormat | Reader | |
| SKP | Trimble SketchUp | Reader/Writer | |
| SLF | Standard Linear Format (SLF) | Reader | |
| SNOWFLAKE | Snowflake | Reader/Writer | |
| SOSI_GML | SOSI GML | Reader/Writer | |
| SPATIALITE_NATIVE | SpatiaLite | Reader/Writer | |
| SQLITE3 | SQLite Non-Spatial | Reader/Writer | |
| SQLLDR | Oracle SQL Loader | Writer | |
| SQLSERVER | Microsoft SQL Server Server (MSSQL) | Reader/Writer | |
| SQLSERVER_AZURE | Microsoft Azure SQL Database (MSSQL) | Reader/Writer | |
| SQLSERVER_JDBC | Microsoft SQL Server (JDBC MSSQL) | Reader/Writer | |
| SRTMHGT | Shuttle Radar Topography Mission Height (SRTM HGT) | Reader | |
| STL | Standard Triangle/Tesselation Language (STL) | Reader/Writer | |
| STRUMAP | Northgate StruMap | Reader/Writer | |
| SUNRASTER | Sun Raster | Reader/Writer | |
| SURFERBINARY | Golden Software Surfer Binary Grid | Reader/Writer | |
| SVG | Scalable Vector Graphics (SVG) | Writer | |
| SXF | Panorama Storage and eXchange Format (SXF) | Reader | |
| SYNAPSE_SQL_JDBC | Microsoft Azure Synapse SQL (Data Warehouse) | Reader/Writer | |
| TARGA | Truevision TGA (TARGA) | Reader | |
| TERADATA_JDBC | Teradata | Reader/Writer | |
| TERRAINTILESAWS | Terrain Tiles on AWS | Reader | |
| TERRASCAN | Terrasolid TerraScan | Reader/Writer | |
| TEST_DELETE | test_delete | Reader | |
| TETGEN | TetGen | Reader/Writer | |
| TEXTLINE | Text File | Reader/Writer | |
| TIFF | Tagged Image File Format (TIFF) | Reader/Writer | |
| TIGER | U.S. Census Bureau TIGER/Line | Reader | |
| TIGERGML | U.S. Census Bureau TIGER/GML | Reader | |
| TOMTOM_POI | TomTom POI | Reader/Writer | |
| TOP10 | Dutch TOP10 GML | Reader/Writer | |
| TOP50NL | Dutch TOP50NL GML | Reader | |
| TOPOJSON | TOPOJSON (Topology JavaScript Object Notation) | Reader/Writer | |
| UDATASMITH | Epic Games Unreal Datasmith | Writer | |
| UFO | Danish UFO | Reader/Writer | |
| USD | Pixar USD (Universal Scene Description) | Writer | |
| USGS_DEM | U.S. Geological Survey Digital Elevation Model (USGSDEM) | Reader/Writer | |
| VML | Vector Markup Language (VML) | Writer | |
| VPF_DB | Vector Product Format Database (VPF_DB) | Reader | |
| VRT | OGR Virtual Dataset (VRT) | Reader | |
| VRT_RASTER | VRT Raster (GDAL Virtual Format) | Reader | |
| WCS | WCS (Web Coverage Service | Reader | |
| WEBP | Google WebP | Reader/Writer | |
| WFS | Web Feature Service (WFS) | Reader | |
| WHITESTAR | Halliburton GeoGraphix CDF | Reader/Writer | |
| WKB | OGC Well Known Binary (WKB) | Reader | |
| WKT | OGC Well Known Text (WKT) | Reader | |
| WLAS | Well Log Ascii Standard | Reader | |
| WMS | WMS (Web Map Service) | Reader | |
| WMTS | WMS (Web Map Tile Service) | Reader | |
| X3D | X3D | Writer | |
| X3D_VRML | Virtual Reality Modeling Language (VRML) | Writer | |
| XDK | XDK (XML format for Danish DSFL) | Reader | |
| XLSXR | Microsoft Excel | Reader | |
| XLSXW | Microsoft Excel | Writer | |
| XML | Extensible Markup Language (XML) | Reader/Writer | |
| XPM | X11 Pixmap (XPM) | Reader/Writer | |
| XSD_DRIVEN_XML | XSD-Driven XML | Reader/Writer | |
| XYZ | Space Delimited XYZ | Reader | |
| ZARR | Raster | Reader/Writer | |
| ZFS | Z+F LaserControl ZFS | Reader | |
| ZGF | Landmark Zycor Graphics File (ZGF) | Reader | |
| ZMAP | Landmark Z-Map (ASCII) | Writer | |
| ZMAPRASTER | Landmark Z-Map Grid | Reader/Writer | |
| ZMAPRAW | Landmark Z-Map Vector | Reader |
