AIXM export configuration files
Disponible avec une licence Aviation Charting.
There are three Aeronautical Information Exchange Model (AIXM) export configuration files that are used to configure the Export AIXM 5.1 Message tool: 51ExportTemplate.xml, 51ExportRelationships.json, and AIXM51ExportDomains.json. They work together to export AIS data out of an ArcGIS Pro AIS database into an AIXM .xml file.
The following three configuration files export AIS data out of an ArcGIS Pro AIS database into an AIXM .xml file:
  • 51ExportTemplate.xml—Defines the supported AIXM output structures. It transforms AIS data into an AIXM .xml file.
  • 51ExportRelationships.json—Defines the AIS queries that join related tables to each other to create related data. Primary table data combined with this related data is substituted into the 51ExportTemplate to create complete AIXM features.
  • AIXM51ExportDomains.json—Defines the AIS to AIXM domain mapping applied during export for fields that require mapping.
The files are located in <Installation location>\Pro\Resources\Aviation. Only the 51ExportTemplate.xml, 51ExportRelationships.json, and AIXM51ExportDomains.json files are used to configure the Export AIXM 5.1 Message tool.
Attention :
It is recommended that you create backup copies of the outlined configuration files before editing them to avoid data loss.
AIXM export diagram
The following diagram shows the three file configurations and how they work together to export AIS data from an ArcGIS database to an AIXM .xml file:
Three file configurations and the export process from an ArcGIS database to an AIXM .xml file
