Download and install product files
Disponible avec une licence ArcGIS Maritime.
Product data files provide business rules and a framework for becoming productive by ensuring standardization and consistency across your operations. Preconfigured databases, cartographic templates, applications, and services help you produce high-quality authoritative content that can be used to publish maps, perform analysis, and share the results throughout your organization.
ArcGIS Pro product files work with the extension. Once ArcGIS Pro and the extension are installed and authorized, you can download and install the product files.
Download
Download options can be viewed after you sign in to My Esri.
Remarque :
You must have the appropriate privileges to access downloads from your My Esri account.
  1. Sign in to My Esri.
  2. Click the Downloads tab.
    A list of the latest versions for various software options appears.
  3. Click the software with the product files you want to download.
    The expanded Product components node for the software appears. Downloadable content is organized by node.
  4. Locate the extension in the Data and content node, and click Download.
    Remarque :
    Expand the Data and content node if necessary.
    The product files installer download begins.
Install
The downloaded product files contain the setup program.
  1. Start the extraction program you downloaded in the previous steps.
  2. Optionally, change the destination folder for the extraction.
  3. Click Next.
  4. Click Close.
    The Launch the setup program check box is checked by default and starts the product files installation.
    Remarque :
    To run the setup program later, uncheck Launch the setup program before clicking Close. Browse to the installer destination folder to open the installer (.msi file) at a later time.
  5. Click Next.
  6. Review the license agreement and accept it if you agree.
  7. Click Next.
    The setup program Destination Folder page appears with the default installation location shown: C:\Users\Public\Documents.
  8. Optionally, click Change to choose a different destination folder.
  9. Click Next.
  10. Click Install.
  11. Click Finish.
    The product files are installed at the specified location.
Maritime product file folders
The ArcGIS Maritime product files installer contains product files used in data and map production.
The Maritime product files installer copies the following folders to the specified installation location (<ArcGIS Maritime installation_location>\ArcGIS Maritime\Product Files\<version>):
  • Charting
    • Grid Definitions
    • Rules
    • Schema
    • Symbols
    • Tools
      • Paper Charting toolbox
      • ArcGIS Maritime Chart Automation Tool Quick Reference Guide
      • Chart Automation Python scripts
      • ZOC diagram Python scripts
  • S-57
    • Product Geodatabase Schemas
    • Product Geodatabase Topology Definitions
    • bIENC.lyrx
    • ENC.lyrx
    • IENC2_4.lyrx
    • IENC2_5.lyrx
    • IENC2_6.lyrx
    • IENC2_4_product.xml
    • IENC2_5_1_product.xml
    • S57Dump.exe
  • S-100
    • S-100 GML Tools.tbx
    • S-124 Feature Catalogue—XML and HTML formats
    • S-131 Feature Catalogue—XML and HTML formats
    • S-401FeatureClassSubtypeMapping.xml
  • S-101
    • S57CoproductionSchemaSupplement.xml
    • S-101 Group.lyrx
    • S-101 Feature Catalogue —XML and HTML formats
    • S101Dump.exe
    • S-101FeatureClassSubtypeMapping.xml
  • VPF
    • DNC
      • Batch Jobs
      • Built Schemas
      • Cartography
      • Templates
  • Workflow
    • Depth Processing toolbox
