Excel worksheets for geodatabases
Portail de licences Disponible avec une licence ArcGIS Topographic Mapping.
The Microsoft Excel file that is used to generate a geodatabase with the Generate Geodatabase From Excel tool consists of multiple worksheets based on the components of the geodatabase. The individual worksheets in the file contain the spatial reference, datasets, object classes, subtypes, fields, domains, and metadata to include in the database.
These worksheets have a specified format and cannot be altered. The information in the worksheets, other than the column names, can be modified.
The following sections describe the worksheets and the columns on each.
SpatialReferences worksheet
The SpatialReferences worksheet contains information about the spatial reference of the dataset containers or object classes. You can create one record for each spatial reference you want to use with the geodatabase, which allows you to specify the spatial reference for individual feature classes or datasets.
The following table contains the one spatial reference that the geodatabase will use, GCS_WGS_1984. If a different spatial reference is required for another dataset in the geodatabase, another record can be created for it.
Example of the SpatialReferences worksheet
An example of the SpatialReferences worksheet is shown.
Conseil :
The SpatialReferenceString field supports well-known text of coordinate reference systems (WKT or WKT-CRS) values, in which case the FactoryCode field can remain blank. Either the FactoryCode or the SpatialReferenceString field must have a valid value.
The following table provides details about the Spatial References worksheet including the types of information that can populate each one.
Column name
Notes
SpatialReference_ID
An identifier that is used in the DatasetContainers or ObjectClasses worksheet
The identifier allows you to specify the spatial reference for a dataset or feature class.
The name of the spatial reference to be used for the identified datasets or object classes
FactoryCode
The code for the coordinate system definition
Custom projection parameters
VerticalDescription
The name of the vertical coordinate system to be used for the identified datasets or object classes
VerticalFactoryCode
The code for the vertical coordinate system definition
XMin
The minimum value for the x-coordinate of the defined bounding box of the data container
The x-coordinate is the longitude coordinate of the world axis.
YMin
The minimum value for the y-coordinate of the defined bounding box of the data container
The y-coordinate is the latitude coordinate of the world axis.
XMax
The maximum value for the x-coordinate of the defined bounding box of the data container
YMax
The maximum value for the y-coordinate of the defined bounding box of the data container
XYPrecision
The inverse of the xy resolution
ZMin
The minimum value for the z-coordinate of the defined bounding box of the dataset container
ZMax
The maximum value for the z-coordinate of the defined bounding box of the dataset container
ZPrecision
The inverse of the z-resolution
MMin
The minimum value for the m- or measurement coordinates of the defined bounding box of the dataset container
M-values are used to store measured distances along a line feature that are independent of the actual geometry lengths. They allow you to store more information directly in the geometry.
MMax
The maximum value for the m- or measurement coordinate of the defined bounding box of the dataset container
MPrecision
The inverse of the M resolution
Spatial Reference worksheet
DatasetContainers worksheet
The DatasetContainers worksheet contains information about the feature datasets, including the type and spatial reference. Each dataset is assigned a unique identifier that can be referenced when you are creating object classes. The following table creates one dataset in the geodatabase, CTM, and it has a unique identification number associated with it.
Example of a DatasetContainers worksheet
An example of a DatasetContainers worksheet is shown.
The following table describes each column on the DatasetContainers worksheet and provides details about the types of information that can populate each one, as applicable.
Column name
Notes
Dataset_ID
A unique identifier for the feature datasets that will be created
This number is used to reference the feature dataset in other worksheets.
CreateDataset
A Boolean field that indicates whether the feature dataset will be created
DatasetType
Describes the Esri dataset type constant, for example, feature dataset
DatasetName
The name of the dataset type that will be created
SpatialReference_ID
A reference to the spatial reference that will be used when the dataset type is created
The ObjectClasses worksheet contains information about the feature classes and tables that will be included in the geodatabase. The Dataset_ID field references feature datasets, which contain the feature classes and tables. The following table references one dataset.
Example of the ObjectClasses worksheet
An example of the ObjectClasses worksheet is shown.
The following table describes each column on the Object Classes worksheet and provides details about the types of information that can populate each one, as applicable.
Column name
Notes
ObjectClass_ID
A unique identifier for the object classes (feature classes or tables) that will be created
This number is used to reference the object class in other worksheets.
Dataset_ID
A reference to the Dataset_ID column on the DatasetContainers worksheet
The value in this column specifies which dataset will contain the feature class or table. If the feature class or table is not part of a dataset, the value in this column should be less than 1 (preferably -9999).
CreateObjectClass
A Boolean field that indicates whether the specified object class will be created
ObjectClassName
The name of the object class that will be created
This name is subject to the ArcGIS Pro restrictions on feature class and table names.
ObjectClassAlias
The alias name for the specified object class
This is the name in the Contents pane when the object class is added to ArcGIS Pro.
ObjectClassDescription
An optional field that can be used to further describe the specified object class
ObjectClassDataType
The type of object class that will be created (feature class, table, and so on)
Possible values for this column are as follows:
  • esriDTFeatureClass—Feature classes (points, lines, and polygons)
  • esriDTTable—Tables (nonspatial data)
ObjectClassFeatureType
The types of features that will be stored in the specified object class (simple, annotation, and so on)
  • esriFTSimple—Simple features such as polygons, polylines, and points
  • esriFTAnnotation—Place or object names or identifiers
Leave this column blank for tables.
ObjectClassGeometry
The type of feature geometry that will be stored in the specified object class (point, line, and polygon)
  • esriGeometryPoint—A single zero dimensional geometry
  • esriGeometryPolyline—An ordered collection of paths
  • esriGeometryPolygon—A collection of rings ordered by their containment relationship
SpatialReference_ID
A reference to the SpatialReference_ID column on the SpatialReferences worksheet
HasZ
A Boolean field that indicates whether the specified object class will store z-values
HasM
A Boolean field that indicates whether the specified object class will store m-values
Subtypes worksheet
The Subtypes worksheet contains information about the subtypes. This includes the unique identification number for each subtype as well as the feature class with which it is associated. When there are multiple subtypes in a feature class, you can assign a default subtype to the feature class.
Example of the Subtypes worksheet
An example of the Subtypes worksheet is shown.
The following table describes each column on the Subtypes worksheet and provides details about the types of information that can populate each one, as applicable.
Column name
Notes
Subtype_ID
A unique identifier for the subtypes
It is used on other worksheets to reference the subtype.
ObjectClass_ID
A reference to the ObjectClass_ID column on the ObjectClasses worksheet
The value in this column specifies which feature class will contain the subtype.
CreateSubtype
A Boolean field that indicates whether the specified subtype will be created
SubtypeField
The integer field in the feature class that stores the subtype codes
SubtypeNumber
The integer value that serves as the code for the specified subtype
SubtypeName
The name of the subtype that will be created
SubtypeDescription
An optional description of the specified subtype
SubtypeDefault
A Boolean field that indicates whether the specified subtype is the default subtype for a feature class
If there are multiple rows for one feature class (that is, it contains multiple subtypes), only one of those rows should contain a value of True in this column because there can only be one default.
Subtypes worksheet
Fields worksheet
The Fields worksheet contains information about the fields on the feature classes, including the object classes, subtypes, and domains with which they are associated. There is one entry per field for each subtype or feature class. This means that if you have the same field in multiple feature classes, it must be added for each feature class and subtype. For example, in the following table, FCSubtype and F_CODE are fields that are included in both subtype 2 and 3 for object class 2.
Example of the Fields worksheet
An example of the Fields worksheet is shown.
The order of the fields is determined by the order in this worksheet. You can define all of the fields in the first subtype and include only the fields with a valid default value or domain in the subsequent subtypes.
The following table describes each column on the Fields worksheet and provides details about the types of information that can populate each one, as applicable.
Column name
Notes
Field_ID
A unique identifier for the field for a subtype or feature class
ObjectClass_ID
The value in this column specifies which feature class or table will contain the field.
Subtype_ID
A reference to the Subtype_ID column on the Subtypes worksheet
The value in this column specifies which subtype will contain the field. If the feature class defined in the ObjectClass_ID field does not contain any subtypes, use -9999.
CreateField
A Boolean field that indicates whether the field will be created
FieldName
The name of the field that will be created
This name is subject to the ArcGIS Online restrictions on field names. Field names in the same table or feature class must be unique (you cannot have two fields with the same name).
FieldAlias
The alias name (alternate name) of the field
The field alias can be used to show a more descriptive version of the field name.
FieldDescription
An optional field that can be used to further describe the field
FieldDomainName
The name of the coded value or range domain associated with the field
If the specified field is not constrained by an attribute domain, leave the Field Domain Name value blank.
FieldType
The types of values that will be stored in the field (text, integer, and so on)
Possible values for this field include the following:
  • esriFieldTypeBlob—OLE Object
  • esriFieldTypeDate—Date/Time field
  • esriFieldTypeDouble—Number, Double, field
  • esriFieldTypeGlobalID—Number, Replication ID, field
  • esriFieldTypeInteger—Number, Long Integer, field
  • esriFieldTypeString—Text field
FieldDefaultValue
The default value for the field
FieldEditable
A Boolean field that indicates whether the field can be edited
FieldIsNullable
A Boolean field that indicates whether the field can contain null values
FieldLength
The maximum number of allowable characters for the field value
This option is only applicable for String or BLOB field types.
FieldPrecision
The number of digits that can be stored in the field
All digits are counted, regardless of which side of the decimal they are on. This column is only used for Double and Integer field types.
FieldScale
The number of decimal places stored in a field
This column is only used for Double field types.
Fields worksheet
Domains worksheet
The Domains worksheet contains information about coded value and range domains. The domains can be created to populate a more general range of values, such as an existence category, or they can be created specifically for a feature class or subtype field. With some databases, the individual subtypes can be domain values.
In the following table, a unique Domain_ID value is assigned to each possible domain value. The values are then grouped based on the domain name.
Example of the Domains worksheet
An example of the Domains worksheet is shown.
The following table describes each column on the Domains worksheet and provides details about the types of information that can populate each one, as applicable.
Column name
Notes
Domain_ID
A unique identifier for each domain value
CreateDomain
A Boolean field that indicates whether the domain will be created
Name
The name of the domain
This name is subject to the ArcGIS Pro restrictions on domain names.
An optional field that can be used to further describe the domain
DomainCode
A number that represents a value in a coded domain
This column is applicable to the Coded Domain data type.
DomainMin
The minimum value of a range domain
DomainMax
The maximum value of a range domain
DomainDescription
A description of what the coded value represents
DomainDataType
The type of domain (Coded Value or Range)
  • esriDTRange—Range Domain
  • esriDTCodedValue—Coded Value Domain
DomainFieldType
The types of values to be stored in the domain (text, integer, and so on)
This value must be the same as the Field Type value on the Fields worksheet for any fields with which the domain is associated. Possible values for this column are as follows:
  • esriFieldTypeDouble—Number, Double field
  • esriFieldTypeInteger—Number, Long Integer field
DomainSplitPolicy
The behavior of an attribute's values when a feature that is split is controlled by a split policy
  • esriSPTDefaultValue—The two resulting features inherit the default value of the specified feature class or subtype attribute.
  • esriSPTDuplicate—The two resulting features inherit a copy of the original object's attribute value.
  • esriSPTGeometryRatio—The attributes of resulting features are a ratio of the original feature's value. The ratio is based on the proportion into which the original geometry is divided. If the geometry is divided equally, each new feature's attribute gets one-half the value of the original object's attribute. The geometry ratio policy only applies to range domains.
DomainMergePolicy
The behavior of attribute values when two features are merged into a single feature
  • esriMPTAreaWeighted—The attribute of the resulting feature is the weighted average of the attribute values of the original features. This average is based on the original feature's geometry. The area weighted policy only applies to range domains.
  • esriMPTDefaultValue—The attribute of the resulting feature inherits the default value of the attribute of the specified feature class or subtype. This is the only merge policy that applies to nonnumeric fields and coded value domains.
  • esriMPTSumValues—The attribute of the resulting feature inherits the sum of the values from the original feature's attribute. The sum values policy only applies to range domains.
Domains worksheet
MetaInfo worksheet
The MetaInfo worksheet contains feature class-level metadata information that is used to create fields on existing or newly created feature classes. Having metadata items defined on the MetaInfo worksheet allows you to include that set of fields on any feature class. For example, in the following graphic, the fields that are listed on the MetaInfo worksheet create a set of metadata attributes that can be added to all the feature classes in the database.
Example of the MetaInfo worksheet
An example of the MetaInfo worksheet is shown.
This is done on the Fields worksheet, where you can have a row that contains the METADATAINFO keyword in the FieldName column. In the example below, row 22 of the Fields worksheet uses METADATAINFO as the FieldName value, meaning that the attributes listed on the MetaInfo worksheet will be added to the end as metadata for the feature class. This eliminates the need to add metadata fields to each applicable feature class.
The following table describes each column on the MetaInfo worksheet and provides details about the types of information that can populate each one, as applicable.
Column name
Notes
MetaInfo_ID
A unique identifier for the metadata field
ObjectClass_ID
This reference is not needed for the MetaInfo worksheet; use -9999.
Subtype_ID
CreateMetaInfo
A Boolean field that indicates whether the specified metadata field will be created
MetaInfoName
The name of the metadata field that will be created
This name is subject to the ArcGIS Pro restrictions on field names. Field names in the same table or feature class must be unique (you cannot have two fields with the same name).
MetaInfoAlias
The alias name (alternate name) of the metadata field
The metadata field alias name can be used to show a more descriptive version of the metadata field name.
MetaInfoDescription
An optional field that can be used to further describe the specified metadata field
MetaInfoDomainName
The name of the coded value or range domain associated with the metadata field
If the specified metadata field is not constrained by an attribute domain, MetaInfoDomainName is blank.
MetaInfoFieldType
The types of values that will be stored in the specified metadata field (text, integer, and so on)
Possible values include the following:
  • esriFieldTypeGlobalID—Number, Replication ID field
MetaInfoDefaultValue
The default value of the metadata field
MetaInfoEditable
A Boolean field that indicates whether the metadata field can be edited
MetaInfoIsNullable
A Boolean field that indicates whether the specified metadata field can contain null values
MetaInfoLength
The maximum number of allowable characters for each record of the metadata field
This option is only applicable for metadata fields that are String or BLOB field types.
MetaInfoPrecision
The number of digits that can be stored in the metadata field
All digits are counted, regardless of which side of the decimal they are on. This parameter is only used in Double and Integer metadata field types.
MetaInfoScale
The number of decimal places stored in a metadata field
This is only applicable in Double data field types.
MetaInfo worksheet
