An overview of the Data Management toolset
Disponible avec une licence Aviation Charting.
The Data Management toolset contains tools that gather information from related tables to populate source features with aviation data and create copies of features based on related areas of interest (AOIs).
Tool
Calculate ATS Route Attributes
Calculates segment distance and bearing attributes on Air Traffic Service (ATS) route features. The tool can also calculate the FAA specific route attributes on a route segment and route collection.
Generate Airspace Areas
Generates AirspaceArea features from Airspace features.
Generate Airspace Lines
Generates line features in the AirspaceLine feature class from the edges of input Airspace polygon features.
Generate Aviation Cartographic Features
Creates cartographic features based on the area of interest (AOI) in which they're located.
Generate Changeover Points
Creates changeover points along a route collection comprised of an ordered set of ATSRoute segments.
Generate Derived Airspace Geometry
Generates airspace geometry for associated airspace features from an imported AIXM 5.1 message.
Generate Procedure Leg Geometry
Generates geometry from procedure legs to correct loaded AIXM data lacking proper geometry.
Generate Summary Table Data
Collects information from a source cartographic feature class and related tables in an aviation charting database (AIS) and outputs the resulting information to a stand-alone table.
Group Route Segments
Derives additional cumulative information, such as the total distance of a route or route portion from individual segments, to prepare data for charting.
Prepare Aviation Data
Migrates attributes from main aviation data to their cartographic features based on specific JSON scripts. These attributes are used for labeling and symbolizing cartographic features. Attributes defined in the JSON will be copied from their locations in the main feature classes and formatted into output attributes also defined in the JSON.
Process Air Traffic Service Routes
Identifies overlapping Air Traffic Service (ATS) routes and calculates fields in the Target Cartographic Route Features to aid in cartographic display.
Report Aviation Chart Changes
Compares feature classes in two enterprise geodatabase versions and returns the differences in a report. You can filter the reported changes to determine which charts are affected by the differing data sources. You can set filters based on areas of interest (AOI), definition queries, and Report Chart Changes preferences.
