Calculate the MEF for a TPC
Disponible avec une licence Production Mapping.
The Calculate Max Elevation Figures tool computes the maximum elevation figures for a Tactical Pilotage Chart (TPC) based on the type of the highest vertical obstruction in a quadrangle. Two obstruction types influence the calculation: human-made and natural terrain. The calculation differs if one type is higher than the other or if the obstruction is below sea level.
Human-made vertical obstruction
If the highest vertical obstruction within a quadrangle is a human-made feature, the Calculate Max Elevation Figures tool follows this process:
Determine the elevation of the top of the feature (above mean sea level [MSL]).
Add the vertical error figure (vertical accuracy factor of data/source).
Round the resultant sum to the next higher hundred-foot level for the final figure.
Remarque :
The resultant figure is not rounded up to the next higher hundred-foot level when it is an even multiple of 100.
Example
Elevation of Vertical Obstruction (top, above mean sea level) = 6265 ft.
Possible vertical error = + 250 ft.
Sum vertical error and elevation = 6715 ft.
Round to next higher 100 ft. level = 6800 ft.
Maximum Elevation Figure (MEF) = 6<sup>8</sup>
Natural terrain feature vertical obstruction
If the highest vertical obstruction within a quadrangle is a natural terrain elevation, the Calculate Max Elevation Figures tool follows this process:
Determine the highest natural terrain elevation.
Add an allowance of 61 meters (200 feet) for nonrepresented natural or human-made features.
Remarque :
A resultant figure is not rounded up to the next higher hundred-foot level when the addition results in an even multiple of 100.
Example
Highest natural terrain elevation (above mean sea level) = 10115 ft.
Allowance = 200 ft.
Sum elevation, allowance, vertical error = 10565 ft.
Round to next higher 100 ft. level = 10600 ft.
Maximum Elevation Figure (MEF) = 10<sup>6</sup>
Highest feature is below sea level
If the highest vertical obstruction within a quadrangle is below sea level (BSL), the Calculate Max Elevation Figures tool follows this process:
Add the BSL value to the 61-meter (200-foot) allowance, for nonrepresented natural or human-made features.
Remarque :
A resultant figure is not rounded up to the next higher hundred-foot level when it is an even multiple of 100.
Example
Highest terrain elevation (above mean sea level) = - 150 ft.
Allowance = 200 ft.
Sum elevation, allowance, vertical error = 300 ft.
(Even hundred - do not round) = 300 ft.
Maximum Elevation Figure (MEF) = 0<sup>3</sup>
