FeatureClassToNumPyArray
サマリー
The FeatureClassToNumPyArray function converts a feature class to NumPy structured array.
ディスカッション
NumPy is a fundamental package for scientific computing in Python, including support for a powerful N-dimensional array object. For more information, see NumPy in ArcGIS.
To convert tables to a NumPy array, use the TableToNumPyArray function instead.
構文
FeatureClassToNumPyArray(in_table, field_names, {where_clause}, {spatial_reference}, {explode_to_points}, {skip_nulls}, {null_value})
パラメーター 説明 データ タイプ
in_table
The feature class, layer, table, or table view.
String
field_names
A list (or tuple) of field names. For a single field, you can use a string instead of a list of strings.
Use an asterisk (*) instead of a list of fields to access all fields from the input table (BLOB fields are excluded). However, for faster performance and reliable field order, it is recommended that the list of fields be narrowed to only those that are actually needed.
Raster and BLOB fields are not supported. Geometry objects are not supported using the SHAPE@ token, but geometry information can be included using other tokens such as SHAPE@XY (a tuple of the feature's centroid coordinates), SHAPE@AREA, and SHAPE@LENGTH.
Additional information can be accessed using tokens (such as OID@) in place of field names:
  • SHAPE@XY—A tuple of the feature's centroid x,y coordinates.
  • SHAPE@XYZ—A tuple of the feature's centroid x,y,z coordinates.
  • SHAPE@TRUECENTROID—A tuple of the feature's centroid x,y coordinates. This returns the same value as SHAPE@XY.
  • SHAPE@X—A double of the feature's x-coordinate.
  • SHAPE@Y—A double of the feature's y-coordinate.
  • SHAPE@Z—A double of the feature's z-coordinate.
  • SHAPE@M—A double of the feature's m-value.
  • SHAPE@JSON—The Esri JSON string representing the geometry.
  • SHAPE@WKB—The well-known binary (WKB) representation for OGC geometry. It provides a portable representation of a geometry value as a contiguous stream of bytes.
  • SHAPE@WKT—The well-known text (WKT) representation for OGC geometry. It provides a portable representation of a geometry value as a text string.
  • SHAPE@AREA—A double of the feature's area.
  • SHAPE@LENGTH—A double of the feature's length.
  • OID@—The value of the Object ID field.
Export a feature class to a NumPy array. The output array will include a field for the Object ID and a field containing a tuple of the feature's centroid's x,y coordinates.
import arcpy
array = arcpy.da.FeatureClassToNumPyArray(fc, ["OID@", "SHAPE@XY"])
# The first row would look similar to the following:
#  (1, [-147.82339477539062, 64.86953735351562])
print(array[0])
SHAPE@M and SHAPE@Z tokens will only return values if the in_table contains point features and is m-aware (or z-aware). If the in_table contains polygon, polyline, or multipart features, SHAPE@M and SHAPE@Z will return a nan. Any feature class that is not m-aware or z-aware will not support SHAPE@M and SHAPE@Z tokens.
The default value is *.
String
where_clause
An optional expression that limits the records returned. For more information on WHERE clauses and SQL statements, see SQL reference for query expressions used in ArcGIS.
The default value is "".
String
spatial_reference
The spatial reference of the feature class. When this argument is specified, the feature will be projected (or transformed) from the input's spatial reference. If unspecified, the input feature classes' spatial reference will be used. Valid values for this argument are a SpatialReference object or string equivalent.
Use the spatial_reference argument to return coordinates in a different spatial reference. Here, a second feature class is described to access a spatial reference object.
import arcpy
SR = arcpy.Describe(fc2).spatialReference
                                  ["OID@", "SHAPE@XY", "EDUCATION"],
                                  spatial_reference=SR)
The default value is None.
SpatialReference
explode_to_points
Deconstruct a feature into its individual points or vertices. If explode_to_points is set to True, a multipoint feature with five points, for example, is represented by five rows.
The default value is False.
Boolean
skip_nulls
Control whether records using nulls are skipped. It can be either a Boolean True or False, or a Python function or lambda expression.
When set to True, if any of the record's attributes is null (including geometry), the record is skipped. With a False setting, skip_nulls attempts to use all records regardless of nulls. In a NumPy array, a null is represented as a nan (not a number) for floating-point numeric values but not for integers.
Skip all records that include a null.
import arcpy
array = arcpy.da.FeatureClassToNumPyArray(fc, fields, skip_nulls=True)
A Python function or lambda expression can be used to allow finer control, including logging the OID values of all records that include a null value. In both examples below, the lambda expression or function is used to identify OIDs that include null records.
Use a function to capture all records that are skipped because of nulls.
import arcpy
def getnull(oid):
    nullRows.append(oid)
    return True
nullRows = list()
array = arcpy.da.FeatureClassToNumPyArray(table, fields, skip_nulls=getnull)
print(nullRows)
Use a lambda expression to capture all records that are skipped because of nulls.
import arcpy
nullRows = list()
                                    skip_nulls=lambda oid: nullRows.append(oid))
print(nullRows)
注意:
In NumPy arrays, nulls are represented in float types such as nan and in text types such as None. Integer types do not support the concept of null values.
Variant
null_value
Replaces null values from the input with a new value.
null_value is replaced before skip_nulls is evaluated.
Mask all None's in integer fields with a -9999.
import arcpy
fields = ['field1', 'field2']
arcpy.da.FeatureClassToNumPyArray(fc, fields, null_value=-9999)
Mask None's in integer fields with different values using a dictionary.
import arcpy
nullDict = {'field1':-999999, 'field2':-9999}
arcpy.da.FeatureClassToNumPyArray(fc, fields, null_value=nullDict)
注意:
Providing a mask such as -9999 allows integer fields containing nulls to be exported to a NumPy array, but be cautious when using these values in any analysis. The results may be inadvertently skewed by the introduced value.
Integer
戻り値
データ タイプ 説明
NumPyArray
A NumPy structured array.
コードのサンプル
Convert a table to a numpy array and perform some basic statistics with numpy.
import arcpy
import numpy
input = "c:/data/usa.gdb/USA/counties"
arr = arcpy.da.FeatureClassToNumPyArray(input, ('STATE_NAME', 'POP1990', 'POP2000'))
# Sum the total population for 1990 and 2000
print(arr["POP1990"].sum())
print(arr["POP2000"].sum())
# Sum the population for the state of Minnesota
print(arr[arr['STATE_NAME'] == "Minnesota"]['POP2000'].sum())
Use TableToNumPyArray to determine correlation coefficients for two fields.
import arcpy
import numpy
field1 = "INCOME"
field2 = "EDUCATION"
arr = arcpy.da.FeatureClassToNumPyArray(input, (field1, field2))
# Print correlation coefficients for comparison of 2 field values
print(numpy.corrcoef((arr[field1], arr[field2])))
