PixelBlock
サマリー
Defines a group or block of pixels to include for raster processing. The PixelBlockCollection object is made up of one or more PixelBlock objects.
ディスカッション
The PixelBlock object defines a block of pixels within a raster to use for processing. It is used in conjunction with the PixelBlockCollection object to iterate through one or more large rasters for processing.
構文
PixelBlock(data, extent)
名前 説明 データ タイプ
data
A NumPy array containing the pixel values for the pixel block.
If the raster is not multidimensional, the shape of the array should be (rows, columns, bands).
If the raster is multidimensional, the shape of the array should be (slices, rows, columns, bands).
NumPyArray
extent
The spatial extent of the pixel block.
Extent
プロパティ
名前 説明 データ タイプ
cell_size
(読み取り専用)
The cell size of the pixels in the pixel block. This is a tuple containing the cell size in the x-direction and the y-direction (x-size, y-size).
tuple
tlc
(読み取り専用)
The coordinates of the pixel block's upper left corner.
Point
spatial_reference
(読み取り専用)
The spatial reference of the exported image. Supported options include the following:
  • None
  • SpatialReference data type
  • ICS or ICS:<object_id>, where object_id selects the specific raster whose image coordinate system should be used.
If a value is not specified, the spatial reference of the raster dataset is used.
SpatialReference
方法
getData()
Returns the NumPy array within the pixel block.
戻り値
データ タイプ 説明
NumPyArray
The NumPy array object from the pixel block.
コードのサンプル
PixelBlock example
Iterates through pixel blocks to calculate the total area of forest in a land cover raster.
import arcpy
# Specify the input raster
in_raster = arcpy.Raster("landcover.tif")
# Create a PixelBlockCollection
blockCollection = arcpy.ia.PixelBlockCollection(
    in_raster, pixel_block_size = (512, 512), nodata_to_values = -1)
forest_cell_count = 0
# Iterate through each PixelBlock
try:
    while True:
        pixelblock = next(blockCollection)
        np_array = pixelblock.getData()
        forest_cell_count += np.count_nonzero(np_array == 1) # value = 1 is forest class
except StopIteration:
    pass
print("total forest pixels : " + str(forest_cell_count))
