VectorField
サマリー
Visualizes flow direction and magnitude information in a raster with vector symbols.
ディスカッション
For more information about how this function works, see the Vector Field raster function.
The referenced raster dataset for the raster object is temporary. To make it permanent, you can call the raster object's save method.
構文
VectorField(raster_u_mag, raster_v_dir, {input_data_type}, {angle_reference_system}, {output_data_type})
| パラメーター | 説明 | データ タイプ |
raster_u_mag |
The first input raster, which is either the U value or the magnitude. |
Raster |
raster_v_dir |
The second input raster, which is either the V value or the direction. |
Raster |
input_data_type |
The type of vector field your inputs represent.
The default value is Vector-UV. |
String |
angle_reference_system |
Specifies how the direction component was measured.
The default value is Geographic. |
String |
output_data_type |
Specifies the type of vector field your output will represent.
String |
戻り値
| データ タイプ | 説明 |
Raster |
The output raster. |
コードのサンプル
This example creates a vector field for a multidimensional dataset.
from arcpy.ia import *
out_vectorfield_raster = VectorField("magnitude", "direction", "Vector-MagDir",
None, "Vector-UV")
out_vectorfield_raster.save("C:/arcpyExamples/outputs/vector_field_UV.crf")
# Import system modules
import arcpy
# Set the analysis environments
arcpy.env.workspace = "C:/arcpyExamples/data"
# Set the local variables
# create a multidimensional raster object from hycom.nc that
# contains 2 variables water_u and water_v
hycom_raster = arcpy.Raster("C:/data/hycom.nc", True)
# choose the 2 variables from hycom_raster as 2 multidimensional raster
in_raster_u_mag = Subset(hycom_raster, variables = "water_u")
in_raster_v_dir = Subset(hycom_raster, variables = "water_v")
# Run VectorField function
out_vectorField_raster = VectorField(in_raster_u_mag, in_raster_v_dir,
"Vector-UV", "Geographic", "Vector-MagDir")
# Save the output
out_vectorField_raster.save("C:/arcpyExamples/vector_field_magdir.crf")
