BMPFormat
サマリー
The BMPFormat object represents a collection of Microsoft Windows bitmap (BMP) file properties that can be configured and used with the export method on the Layout, MapFrame, and MapView objects to create an output BMP file.
ディスカッション
BMP files are native Windows raster images. BMP files can store pixel data at several bit depths and can be compressed using the lossless RLE method. BMP images are typically much larger than formats such as JPEG or PNG.
The createExportFormat method can be used to create a BMPFormat object if the format parameter is set to BMP. The returned BMPFormat object contains all the properties associated with a generating a BMP file. These properties can be modified accordingly to produce different output results.
プロパティ
| 名前 | 説明 | データ タイプ |
clipToElements (読み取り/書き込み) |
If set to |
Boolean |
colorMode (読み取り/書き込み) |
A string constant that represents the number of bits to describe color in a pixel. The default value is
String |
filePath (読み取り/書き込み) |
A string that represents the system path and file name, including the extension, for the exported file. |
String |
geoReferenceMapFrame (読み取り/書き込み) |
The MapFrame used to control the coordinate system when the |
MapFrame |
height (読み取り/書き込み) |
The height, in pixels, of the map area to be exported. This property only applies when exporting a |
Double |
resolution (読み取り/書き込み) |
The effective dpi of the output vector data. The default value is 96. 注意:When exporting a |
Integer |
showSelectionSymbology (読み取り/書き込み) |
Show selected features in the map or map frame as selected in the output file. Setting this value to |
Boolean |
threshold (読み取り/書き込み) |
Image intensities set above this value will appear white in the output file and all other values will appear black. This property is applied only when the |
Boolean |
width (読み取り/書き込み) |
The width, in pixels, of the map area to be exported. This property only applies when exporting a |
Double |
worldFile (読み取り/書き込み) |
If set to |
Boolean |
方法
setColorMode(bmp_color_mode)
| 名前 | 説明 | データ タイプ |
bmp_color_mode |
Below is a list of valid strings.
String |
コードのサンプル
The following script exports a layout to BMP format using default property values.
p = arcpy.mp.ArcGISProject('current')
lyt = p.listLayouts()[0]
bmp = arcpy.mp.CreateExportFormat('BMP', r'C:\Temp\output.bmp')
lyt.export(bmp)
