GraduatedSymbolsRenderer
サマリー
The GraduatedSymbolsRenderer class represents the graduated symbols renderer definition that shows qualitative differences in feature values using a range of symbol sizes.
ディスカッション
The properties behave in a similar manner to the options exposed in the application. For example, changing the number of classes will automatically adjust the break values and their labels. If you change upperBound of a ClassBreak, the classificationMethod automatically changes to ManualInterval. You also need to manually update the labels and/or descriptions properties accordingly.
プロパティ
| 名前 | 説明 | データ タイプ |
backgroundSymbol (読み取り/書き込み) |
A symbol that represents the background symbol for the features in the layer. It only applies to polygon feature classes. |
Symbol |
breakCount (読み取り/書き込み) |
An integer that represents the number of classes to be used with the current classification method. |
Integer |
classBreaks (読み取り/書き込み) |
A list of ClassBreak objects that provides access to individual properties such as |
List |
classificationField (読み取り/書き込み) |
A string that represents a valid field name used for the layer's classification method. |
String |
classificationMethod (読み取り/書き込み) |
A string that represents a valid classification method. The valid values are as follows:
String |
colorRamp (読み取り/書き込み) |
Provides access to the ColorRamp object. |
ColorRamp |
deviationInterval (読み取り/書き込み) |
A double that represents a valid deviation interval that is only available if the |
Double |
intervalSize (読み取り/書き込み) |
A double that represents an interval size that is only available if the |
Double |
lowerBound (読み取り/書き込み) |
A double that represents the minimum value of the symbolized 注意:The value of the |
Double |
maximumSymbolSize (読み取り/書き込み) |
A double that represents the size of the largest graduated symbol. |
Double |
minimumSymbolSize (読み取り/書き込み) |
A double that represents the size of the smallest graduated symbol. |
Double |
normalizationField (読み取り/書き込み) |
A string that represents a valid layer field name that is used for normalization. |
String |
normalizationType (読み取り/書き込み) |
A specific string that represents a valid normalization key word. For example, to clear the normalization, try
String |
symbolTemplate (読み取り専用) |
Returns a symbol that represents the symbol template for all the features in the layer. To set the template use the |
Symbol |
type (読み取り専用) |
Returns a string that represents the renderer type. |
String |
方法
updateSymbolTemplate(symbol_template)
updateSymbolTemplate provides a mechanism to change the renderer's symbol template.
The updateSymbolTemplate method allows you to modify the symbol for all the class breaks at once. The symbol template is managed in the application differently than other renderer properties, for example, backgroundSymbol, and therefore requires a method to set the symbol template to the renderer.
| 名前 | 説明 | データ タイプ |
symbol_template |
A reference to a symbol. The default value is None. |
Object |
コードのサンプル
The following script first tests if the layer's symbology supports a renderer property. It then confirms if the renderer is a GraduatedSymbolsRenderer. Next, it sets up the backgroundSymbol and symbolTemplate. Next, it changes the classificationField and breakCount and also sets the minimum and maximum symbol sizes. Finally, it changes ColorRamp to a color ramp named Black to White.
import arcpy, os, sys
relpath = os.path.dirname(sys.argv[0])
p = arcpy.mp.ArcGISProject(relpath + r"\\GraduatedSymbols.aprx")
m = p.listMaps("Layers")[0]
l = m.listLayers("Natural*")[0]
sym = l.symbology
if hasattr(sym, 'renderer'):
if sym.renderer.type == "GraduatedSymbolsRenderer":
#set background symbol
sym.renderer.backgroundSymbol.applySymbolFromGallery("Extent Transparent Wide Gray")
#set symbol template
symTemp = sym.renderer.symbolTemplate
symTemp.applySymbolFromGallery('Square 1')
sym.renderer.updateSymbolTemplate(symTemp)
#modify graduated symbol renderer
sym.renderer.classificationField = "Shape_Area"
sym.renderer.breakCount = 6
sym.renderer.minimumSymbolSize = 10
sym.renderer.maximumSymbolSize = 25
sym.renderer.colorRamp = p.listColorRamps("Black to White")[0]
l.symbology = sym
p.saveACopy(relpath + r"\\SavedOutput.aprx")
The following script modifies the lowerBound and upperBound property values for the renderer's symbolized classificationField. It also uses Python CIM access to display the out of range classificationField values using a default symbol that is automatically generated.
p = arcpy.mp.ArcGISProject('current')
m = p.listMaps('LowerBoundResult')[0]
l = m.listLayers()[0]
if hasattr(l.symbology, 'renderer'):
if l.symbology.renderer.type == 'GraduatedColorsRenderer':
sym = l.symbology
#Set lowerBound set on Renderer
sym.renderer.lowerBound = 5
#Set upperBound set on upper ClassBreak
sym.renderer.classBreaks[-1].upperBound = 96
l.symbology = sym
#Show values out of range using Python CIM Access
l_cim = l.getDefinition('V3')
l_cim.renderer.useDefaultSymbol = True
l_cim.renderer.defaultLabel = "Out of range"
l.setDefinition(l_cim)
