MapSeriesExportOptions
サマリー
The MapSeriesExportOptions object represents a collection of optional properties that can be used with the export method on the MapSeries and BookmarkMapSeries objects to configure how a map series is exported.
ディスカッション
This object is only needed if you want to export a MapSeries or BookmarkMapSeries with properties different than the default values.
The CreateExportOptions function can be used to create a MapSeriesExportOptions object if the class_type parameter is set to MAPSERIES. The returned object contains all the properties needed to configure how map series are exported.
注意:
Currently map series objects can only be exported to JPEGFormat, PNGFormat, PDFFormat and TIFFFormat.
プロパティ
名前 説明 データ タイプ
customPages
(読み取り/書き込み)
A string that identifies the map series pages to be exported if the exportPages property is set to CUSTOM. For example, the following string would export 5 pages: 1, 3, 5-7. The default value is an empty string.
String
exportFileOptions
(読み取り専用)
A string constant that represents how the pages will be exported. To change this value, use the setFileExportOptions method. The default value is PDF_SINGLE_FILE.
  • PDF_MULTIPLE_FILES_PAGE_NAME—Export each map series page to an individual file and append the page name to the file name. For example, Output.PDF will become Output_LakeErie.PDF.
  • PDF_MULTIPLE_FILES_PAGE_NUMBER—Export each map series page to an individual file and append the page number to the file name. For example, Output.PDF will become Output_1.PDF.
  • PDF_SINGLE_FILE—Export all pages into a multipage, single file document.
String
exportPages
(読み取り専用)
A string constant that represents the collection of map series pages to be exported. To change this value, use the setExportPages method. The default value is ALL.
  • ALL—Export all pages in the map series.
  • CURRENT—Export the currently active page. This option only applies when running a script inside the application.
  • CUSTOM—Export a custom set of pages that is defined using the customPages property.
  • SELECTED_INDEX_FEATURES—Only export map series pages that correspond to the selected index features associated with the map series.
String
showExportCount
(読み取り/書き込み)
If set to True, you will see the status of each page being exported displayed in the Python shell. The default value is False.
Boolean
方法
setExportFileOptions(export_file_options)
The default value is PDF_SINGLE_FILE when exporting to PDFFormat. If you are exporting to JPEGFormat, [PNGFormat], or TIFFFormat, and you don't explicitly set this parameter, it will default to MULTIPLE_FILES_PAGE_NAME instead since only PDFFormat supports exporting multiple pages to a single file.
名前 説明 データ タイプ
export_file_options
  • MULTIPLE_FILES_PAGE_NAME—Export each map series page to an individual file and append the page name to the file name. For example, Output.PDF will become Output_LakeErie.PDF.
  • MULTIPLE_FILES_PAGE_NUMBER—Export each map series page to an individual file and append the page number to the file name. For example, Output.PDF will become Output_1.PDF.
String
setExportPages(export_pages)
名前 説明 データ タイプ
export_pages
String
コードのサンプル
MapSeriesExportOptions example
The following script exports a MapSeries object using default PDFFormat properties but configures the MapSeriesExportOptions to export a custom set of map series pages.
p = arcpy.mp.ArcGISProject('current')
l = p.listLayouts('Layout_MS')[0]
ms = l.mapSeries
pdf = arcpy.mp.CreateExportFormat('PDF', r'c:\temp\MS_PDF.pdf')
msExOpt = arcpy.mp.CreateExportOptions('MAPSERIES')
msExOpt.setExportPages('CUSTOM')
msExOpt.customPages = '1-3'
ms.export(pdf, msExOpt)
