HfForward
サマリー
Defines the relationship between the horizontal cost factor and the horizontal relative moving angle through a forward function. The function establishes that only forward movement is allowed.
HfForward horizontal factor graph
Graph of the forward horizontal factor.
ディスカッション
This object is used in the Distance Accumulation and Distance Allocation Spatial Analyst tools, as well as the Path Distance, Path Distance Allocation, and Path Distance Back Link Legacy Distance tools.
If a horizontal relative moving angle (HRMA) is less than 45 degrees for a section of travel, the horizontal factor (HF) is set to the value associated with the zeroFactor. When the HRMA is larger than or equal to 45 degrees and less than 90 degrees, the HF is set to the sideValue. If the HRMA is equal to or greater than 90 degrees, the HF is set to infinity.
構文
HfForward({zeroFactor}, {sideValue})
名前 説明 データ タイプ
zeroFactor
(オプション)
The zeroFactor will be used to position the y-intercept of the forward function.
The default value is 0.5.
Double
sideValue
(オプション)
Identifies the HF value that will be assigned for HRMAs that are equal to or less than 45 degrees and less than 90 degrees. In the diagram above, the sideValue is assigned 1.
The default value is 1.0.
Double
プロパティ
名前 説明 データ タイプ
zeroFactor
(読み取り/書き込み)
The zeroFactor will be used to position the y-intercept of the function.
The zeroFactor is assigned as the horizontal factor when HRMA is less then the cut angle.
Double
sideValue
(読み取り/書き込み)
Identifies the HF value that will be assigned for HRMAs that are equal to or less than 45 degrees and less than 90 degrees. In the diagram above the sideValue is assigned 1.
Double
コードのサンプル
HfForward example 1 (Python window)
Demonstrates how to create an HfForward class and use it in the DistanceAccumulation tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myHorizFactor = HfForward(0.5, 1.0)
outDistAccum = DistanceAccumulation("source.shp", "barrier.tif",
                                    "elev.tif", "", "", "",
                                    "horizontalRas.tif", myHorizFactor)
outDistAccum.save("C:/sapyexamples/output/distaccumhff")
HfForward example 2 (stand-alone script)
Performs a distance accumulation analysis using the HfForward class.
# Name: HfForward_Ex_02.py
# Description: Uses the HfForward object to run the
#              DistanceAccumulation tool.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inSourceData = "sourcepts.shp"
inSurfaceRaster = "elevation.tif"
inHorizontalRaster = "horizontalRas.tif"
# Create the HfForward Object
zeroFactor = 0.5
sideValue = 1.0
myHorizFactor = HfForward(zeroFactor, sideValue)
# Run PathDistance
outDistAccum = DistanceAccumulation(inSourceData,"", inSurfaceRaster,"","",
                                    "", inHorizontalRaster, myHorizFactor)
# Save the output
outDistAccum.save("C:/sapyexamples/output/distaccumhfF2")
