Logical Math geoprocessing functions
Spatial Analyst ライセンスで利用可能。
Image Analyst ライセンスで利用可能。
The Logical Math geoprocessing functions evaluate the values of the inputs and determine the output values based on Boolean logic. The geoprocessing functions are grouped into four main categories: Boolean, Combinatorial, Logical, and Relational.
The following is a list of all the geoprocessing functions within each grouping:
  • Boolean:
    Boolean And, Boolean Or, Boolean XOr, Boolean Not
  • Combinatorial:
    Combinatorial And, Combinatorial Or, Combinatorial XOr
  • Relational:
    Equal To, Not Equal, Greater Than, Greater Than Equal, Less Than, Less Than Equal
  • Logical:
    Diff, InList, Is Null, Over, Test
Boolean logic generally applies a binary condition to the inputs and evaluates to a binary condition for the output. The binary condition can be expressed in several ways: "1" and "0", "True" and "False", "yes" and "no", "on" and "off", and so forth. In the Logical Math geoprocessing functions, the False condition is represented with a value of 0, and the True condition as any value other than 0.
The Boolean geoprocessing functions evaluate the inputs only as True or False conditions and return the result of the particular geoprocessing function as a 1 or 0 (True or False) Boolean value. The Combinatorial geoprocessing functions identify unique combinations of input values based on the logic of the particular geoprocessing function and return a different value for each unique combination. The Relational geoprocessing functions compare the values of one input relative to another and return the result of the particular geoprocessing function as 1 or 0 Boolean value. The Logical geoprocessing functions have different ways to apply Boolean logic, such as identifying only the input cells that are NoData, or using a logical expression that you define to determine which cells are evaluated as true.
The following table lists the available geoprocessing functions and provides a brief description of each.
Boolean evaluation
Geoprocessing Function
Boolean And
Performs a Boolean And operation on the cell values of two input rasters.
If both input values are true (non-zero), the output value is 1. If one or both inputs are false (zero), the output is 0.
Boolean Not
Performs a Boolean Not (complement) operation on the cell values of the input raster.
If the input values are true (non-zero), the output value is 0. If the input values are false (zero), the output is 1.
Boolean Or
Performs a Boolean Or operation on the cell values of two input rasters.
If one or both input values are true (non-zero), the output value is 1. If both input values are false (zero), the output is 0.
Boolean XOr
Performs a Boolean eXclusive Or operation on the cell values of two input rasters.
If one input value is true (non-zero) and the other false (zero), the output is 1. If both input values are true or both are false, the output is 0.
Boolean math geoprocessing functions
Combinatorial evaluation
Combinatorial And
Performs a Combinatorial And operation on the cell values of two input rasters.
If both input values are true (non-zero), the output is a different value for each unique combination of input values. If one or both inputs are false (zero), the output value is 0.
Combinatorial Or
Performs a Combinatorial Or operation on the cell values of two input rasters.
If either input value is true (non-zero), the output is a different value for each unique combination of input values. If both inputs are false (zero), the output value is 0.
Combinatorial XOr
Performs a Combinatorial eXclusive Or operation on the cell values of two input rasters.
If one input value is true (non-zero) and the other false (zero), the output is a different value for each unique combination of input values. If both inputs are true or both are false, the output value is 0.
Combinatorial math geoprocessing functions
Relational evaluation
Equal To
Performs a Relational equal-to operation on two inputs on a cell-by-cell basis.
Returns 1 for cells where the first raster equals the second raster and 0 for cells where it does not.
Greater Than
Performs a Relational greater-than operation on two inputs on a cell-by-cell basis.
Returns 1 for cells where the first raster is greater than the second raster and 0 for cells if it is not.
Greater Than Equal
Performs a Relational greater-than-or-equal-to operation on two inputs on a cell-by-cell basis.
Returns 1 for cells where the first raster is greater than or equal to the second raster and 0 if it is not.
Less Than
Performs a Relational less-than operation on two inputs on a cell-by-cell basis.
Returns 1 for cells where the first raster is less than the second raster and 0 if it is not.
Less Than Equal
Performs a Relational less-than-or-equal-to operation on two inputs on a cell-by-cell basis.
Returns 1 for cells where the first raster is less than or equal to the second raster and 0 where it is not.
Not Equal
Performs a Relational not-equal-to operation on two inputs on a cell-by-cell basis.
Returns 1 for cells where the first raster is not equal to the second raster and 0 for cells where it is equal.
Relational math geoprocessing functions
Logical evaluation
Diff
Determines which values from the first input are logically different from the values of the second input on a cell-by-cell basis.
If the values on the two inputs are different, the value on the first input is output. If the values on the two inputs are the same, the output is 0.
InList
Determines which values from the first input are contained in a set of other inputs, on a cell-by-cell basis.
For each cell, if the value of the first input raster is found in any of the list of other inputs, that value will be assigned to the output raster. If it is not found, the output cell will be NoData.
Is Null
Determines which values from the input raster are NoData on a cell-by-cell basis.
Returns a value of 1 if the input value is NoData and 0 for cells that are not.
Over
For the cell values in the first input that are not 0, the output value will be that of the first input. Where the cell values are 0, the output will be that of the second input raster.
Test
Performs a Boolean evaluation of the input raster using a logical expression.
When the expression evaluates to true, the output cell value is 1. If the expression is false, the output cell value is 0.
Logical math geoprocessing functions
