TopoBoundary
サマリー
Defines a list of feature classes containing polygons that represent the outer boundary of the output raster.
ディスカッション
This object is used in the tool Topo To Raster.
Cells in the output raster outside this boundary will be NoData. This option can be used for clipping out water areas along coastlines before making the final output raster.
The boundary polygons define the locations within which the calculations will be performed.
構文
TopoBoundary(inFeatures)
名前 説明 データ タイプ
inFeatures
The input feature datasets.
String
プロパティ
名前 説明 データ タイプ
inFeatures
(読み取り/書き込み)
String
コードのサンプル
TopoBoundary example 1 (Python window)
Demonstrates how to create a TopoBoundary class and use it in the TopoToRaster tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myTopoPtElev = TopoPointElevation([["spots.shp", "spot_meter"], ["spots2.shp", "elev"]])
myTopoContour = TopoContour([["contours.shp", "spot_meter"]])
myTopoBoundary = TopoBoundary(["boundary.shp"])
myTopoLake = TopoLake(["lakes.shp"])
myTopoSink = TopoSink([["sink1.shp", "elevation"], ["sink2.shp", "NONE"]])
myTopoStream = TopoStream(["streams.shp"])
myTopoCliff = TopoCliff(["cliff.shp"])
myTopoCoast = TopoCoast(["coast.shp"])
myTopoExclusion = TopoExclusion(["ignore.shp"])
outTopoToRaster1 = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream, myTopoCliff, myTopoCoast, myTopoExclusion])
outTopoToRaster1.save("C:/sapyexamples/output/ttraster1")
TopoBoundary example 2 (stand-alone script)
Interpolates a surface with TopoToRaster using the TopoBoundary class as one of the input parameters.
# Name: TopoBoundary_Ex_02.py
# Description: Run TopoToRaster using all the supported objects.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Create all the supported Objects
# Run TopoToRaster
outTopoToRaster = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream])
# Save the output
outTopoToRaster.save("C:/sapyexamples/output/ttraster2")
