TopoPointElevation
サマリー
Defines a list of point feature classes representing surface elevations and the fields identifying their elevation values.
ディスカッション
This object is used in the tool Topo To Raster.
構文
TopoPointElevation(inFeatures)
| 名前 | 説明 | データ タイプ |
inFeatures |
The input point feature datasets. Optionally, you can supply the name of a field that stores the elevation values to use for the input points. |
List |
プロパティ
| 名前 | 説明 | データ タイプ |
inFeatures (読み取り/書き込み) |
The input feature datasets and the fields to be used for the attributes. |
List |
コードのサンプル
TopoPointElevation example 1 (Python window)
Demonstrates how to create a TopoPointElevation class and use it in the TopoToRaster tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myTopoPtElev = TopoPointElevation([["spots.shp", "spot_meter"], ["spots2.shp", "elev"]])
myTopoContour = TopoContour([["contours.shp", "spot_meter"]])
myTopoBoundary = TopoBoundary(["boundary.shp"])
myTopoLake = TopoLake(["lakes.shp"])
myTopoSink = TopoSink([["sink1.shp", "elevation"], ["sink2.shp", "NONE"]])
myTopoStream = TopoStream(["streams.shp"])
myTopoCliff = TopoCliff(["cliff.shp"])
myTopoCoast = TopoCoast(["coast.shp"])
myTopoExclusion = TopoExclusion(["ignore.shp"])
outTopoToRaster1 = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream, myTopoCliff, myTopoCoast, myTopoExclusion])
outTopoToRaster1.save("C:/sapyexamples/output/ttraster1")
TopoPointElevation example 2 (stand-alone script)
Interpolates a surface with TopoToRaster using the TopoPointElevation class as one of the input parameters.
# Name: TopoBoundary_Ex_02.py
# Description: Run TopoToRaster using all the supported objects.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Create all the supported Objects
# Run TopoToRaster
outTopoToRaster = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream])
# Save the output
outTopoToRaster.save("C:/sapyexamples/output/ttraster2")
