TopoStream
サマリー
Defines a list of line feature classes of stream locations.
ディスカッション
This object is used in the tool Topo To Raster.
All lines must be oriented to point downstream.
The feature class should only contain single line streams.
To display the direction of the line sections, change the symbology to include an arrow at the end. This will draw the line sections with an arrow symbol showing the line directions.
構文
TopoStream(inFeatures)
名前 説明 データ タイプ
inFeatures
The input feature datasets.
String
プロパティ
名前 説明 データ タイプ
inFeatures
(読み取り/書き込み)
String
コードのサンプル
TopoStream example 1 (Python window)
Demonstrates how to create a TopoStream class and use it in the TopoToRaster tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myTopoPtElev = TopoPointElevation([["spots.shp", "spot_meter"], ["spots2.shp", "elev"]])
myTopoContour = TopoContour([["contours.shp", "spot_meter"]])
myTopoBoundary = TopoBoundary(["boundary.shp"])
myTopoLake = TopoLake(["lakes.shp"])
myTopoSink = TopoSink([["sink1.shp", "elevation"], ["sink2.shp", "NONE"]])
myTopoStream = TopoStream(["streams.shp"])
myTopoCliff = TopoCliff(["cliff.shp"])
myTopoCoast = TopoCoast(["coast.shp"])
myTopoExclusion = TopoExclusion(["ignore.shp"])
outTopoToRaster1 = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream, myTopoCliff, myTopoCoast, myTopoExclusion])
outTopoToRaster1.save("C:/sapyexamples/output/ttraster1")
TopoStream example 2 (stand-alone script)
Interpolates a surface with the TopoToRaster tool using the TopoStream class as one of the input parameters.
# Name: TopoBoundary_Ex_02.py
# Description: Run TopoToRaster using all the supported objects.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Create all the supported Objects
# Run TopoToRaster
outTopoToRaster = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream])
# Save the output
outTopoToRaster.save("C:/sapyexamples/output/ttraster2")
