VfInverseLinear
サマリー
Defines the relationship between the vertical cost factor and the vertical relative moving angle through an inverse linear function.
VfinverseLinear vertical factor graph
Graph of the inverse linear vertical factor.
ディスカッション
This object is used in the Distance Accumulation and Distance Allocation Spatial Analyst tools, as well as the Path Distance, Path Distance Allocation, and Path Distance Back Link Legacy Distance tools.
The vertical factor (VF) object defines the relationship between the vertical cost factor and the vertical relative moving angle (VRMA).
VF defines the vertical difficulty encountered in moving from one cell to the next.
VRMA identifies the slope angle between the FROM or processing cell and the TO cell.
The VFs are determined by the inverse values from a straight line in the VRMA-VF coordinate system. The line intercepts the y-axis, equitable to the VF factor, the value associated with the zeroFactor. The slope of the line can be identified if specified with the slope argument.
構文
VfInverseLinear({zeroFactor}, {lowCutAngle}, {highCutAngle}, {slope})
名前 説明 データ タイプ
zeroFactor
(オプション)
The zeroFactor will be used to position the y-intercept of the inverse linear function.
The default value is 1.0.
Double
lowCutAngle
(オプション)
The VRMA degree defining the lower threshold, below which (less than) the VFs are set to infinity.
The default value is -45.0.
Double
highCutAngle
(オプション)
The VRMA degree defining the upper threshold, beyond which (larger than) the VFs are set to infinity.
The default value is 45.0.
Double
slope
(オプション)
Identifies the slope of the straight line in the VRMA-VF coordinate system. Slope is specified as the rise/run. For example, a 30-degree slope is 1/30, specified as 0.03333 (rise/run: 1 VF on the y axis / 30 degrees on the x axis); a -45-degree slope as -0.02222.
The default value is -0.022222.
Double
プロパティ
名前 説明 データ タイプ
zeroFactor
(読み取り/書き込み)
The zeroFactor is used to position the y-intercept for the vertical factor class.
Double
lowCutAngle
(読み取り/書き込み)
Double
highCutAngle
(読み取り/書き込み)
Double
slope
(読み取り/書き込み)
Identifies the slope of the straight line in the VRMA-VF coordinate system. Slope is specified as the rise over the run. For example, a 30-degree slope is 1/30, specified as 0.03333 (rise/run: 1 VF on the y axis / 30 degrees on the x axis); a 90-degree slope as 0.011111.
Double
コードのサンプル
VfInverseLinear example 1 (Python window)
Demonstrates how to create a VfInverseLinear class and use it in the DistanceAccumulation tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myVerticalFactor = VfInverseLinear(1.0, -45, 45, -0.02222)
outDistAccum = DistanceAccumulation("Source.shp", "", "elev.tif",
                                   "cost.tif", "elev.tif",
                                    myVerticalFactor)
outDistAccum.save("C:/sapyexamples/output/distAccumVfIL.tif")
VfInverseLinear example 2 (stand-alone script)
Performs a distance accumulation analysis using the VfInverseLinear class.
# Name: VfInverseLinear_Ex_02.py
# Description: Uses the VfInverseLinear object to run the
#              DistanceAccumulation tool
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inSourceData = "source.shp"
inCostRaster = "costraster.tif"
inElevation = "elev.tif"
# Create the VfInverseLinear Object
zeroFactor = 1.0
lowCutAngle = -45
highCutAngle = 45
slope = -0.02222
myVerticalFactor = VfInverseLinear(zeroFactor, lowCutAngle, highCutAngle,
                                    slope)
# Run PathDistance
outDistAccum = DistanceAccumulation(inSourceData, "", inElevation,
                                    inCostRaster, inElevation,
                                    myVerticalFactor)
# Save the output
outDistAccum.save("C:/sapyexamples/output/distaccumvfIL2.tif")
