WindChill
サマリー
Identifies dangerous winter conditions that, depending on exposure times to the elements, can result in frostbite or hypothermia.
ディスカッション
The formula the function uses to compute wind chill is as follows:
\({Wind\ Chill} = 35.74 + (0.6215 * T) - (35.75\ * WS^{0.16}) + (0.4275\ *\ T\ * WS^{0.16})\)
  • T = Air Temperature in degrees Fahrenheit
  • WS = Wind speed in miles per hour
For more information about how this function works, see the Wind Chill raster function.
The referenced raster dataset for the raster object is temporary. To make it permanent, you can call the raster object's save method.
構文
WindChill(temperature_raster, wind_speed_raster, {temperature_units}, {wind_speed_units}, {wind_chill_units})
パラメーター 説明 データ タイプ
temperature_raster
A single-band raster where pixel values represent ambient air temperature.
Raster
wind_speed_raster
A single-band raster where pixel values represent wind speed.
Raster
temperature_units
The unit of measurement associated with the input temperature raster. Available input units are Celsius, Fahrenheit, and Kelvin.
The default value is Fahrenheit.
String
wind_speed_units
Defines the unit of measurement for the wind-speed raster:
  • mph—Miles per hour
  • km/h—Kilometers per hour
  • m/s—Meters per second
  • ft/s—Feet per second
  • kn—Knots
The default value is mph.
String
wind_chill_units
The unit of measurement associated with the output raster. Available output units are Celsius, Fahrenheit, and Kelvin.
String
戻り値
データ タイプ 説明
Raster
The output raster.
コードのサンプル
WindChill example 1
Calculates wind chill based on the temperature and wind speed from the input raster.
from arcpy.sa import *
out_windchill_raster = WindChill("temperature.tif", "windspeed.tif", "",
                                 "km/h", "Celsius")
out_windchill_raster.save("C:/arcpyExamples/outputs/wind_chill_C.tif")
WindChill example 2
# Import system modules
import arcpy
# Set the analysis environments
arcpy.env.workspace = "C:/arcpyExamples/data"
# Set the local variables
in_temperature_raster = "temperature.tif"
in_wind_speed_raster  = "windspeed.tif"
# Run WindChill function
out_windchill_raster = WindChill(in_temperature_raster, in_wind_speed_raster,
                                 "", "knots", "Kelvin")
# Save the output
out_windchill_raster.save("C:/arcpyExamples/outputs/wind_chill_K.tif")
