ArcGIS Data Interoperability extension
Data Interoperability ライセンスで利用可能。
The ArcGIS Data Interoperability extension for Desktop is an integrated spatial extract, transform, and load (ETL) toolset that runs in the geoprocessing framework using Safe Software's FME technology. When using the ArcGIS Data Interoperability extension for Desktop, you can also launch the Workbench application directly, which allows you to author FMW files that you can directly attach to an ETL tool.
ArcGIS Pro
The Data Interoperability extension for ArcGIS Desktop is a separate extension and is a separate install.
Authorizing the ArcGIS Data Interoperability extension for Desktop with a valid license in ArcGIS Pro adds additional out-of-the-box support for creating ETL tools using the FME Workbench application.
The ArcGIS Data Interoperability extension for Desktop uses FME technology.
Capabilities
Capability |
Description |
Spatial ETL tools are user-created geoprocessing tools that can transform data between different data models and different file formats. You create them with FME Workbench in a translation workspace and save them in a toolbox. |
