AIXM51ExportDomains.json structure
Aviation Charting ライセンスで利用可能。
The AIXM51ExportDomains.json file defines the AIS to AIXM domain mappings that will be applied during export for fields that require mapping.
注意:
It is recommended that you create backup copies of the outlined configuration files before editing them to avoid data loss.
Export domain parts
The AIXM51ExportDomains.json file is a JSON structure composed of an AIS source table name, AIS source field name, and AIXM destination feature name. A set of export domain objects in an AIXM destination feature can be defined with each object having aixm_ancestor_name, aixm_path_endswith, and domain values.
The following table describes the structure of the JSON file:
Name |
Description |
A JSON key that is an AIS source table. It is the highest level JSON key in the JSON structure. |
A JSON key that is an AIS source field name from the AIS source table such as |
A JSON key that is an AIXM destination feature name such as |
A JSON value that represents an AIXM ancestor name. It is an advanced setting that helps distinguish domains with similarly named AIXM |
A JSON value that represents a path from the AIXM destination field. It is an advanced setting used with |
A JSON object that represents the domain mapping that will be applied during export of the AIS source field to the AIXM destination. |
Example
This AIXM51ExportDomains example shows two domain mapping definitions. Each domain map is on the same aixm:type destination from the same navaidcomponent.type_code AIS source field. They are each associated with the same aixm:azimuth ancestor. Because of this association, they must be distinguished by configuring the aixm_path_endswith value:
"navaidcomponent": {
"navaidcomponent.type_code": {
"aixm:type": [
"aixm_ancestor_name": "aixm:azimuth",
"aixm_path_endswith": "aixm:azimuthtimeslice/aixm:type",
"domain": {
"b": "BWD",
"f": "FWD",
"n": "NARROW",
"p": "PRECISION",
"w": "WIDE"
"aixm_path_endswith": "aixm:dmetimeslice/aixm:type",
"domain": {
"b": "BWD_2",
"f": "FWD_2",
"n": "NARROW_2",
"p": "PRECISION_2",
"w": "WIDE_2"
If a navaidcomponent.type_code source field has value n and is being written to an aixm:type AIXM field, the domain map is determined using the following logic:
If the field has an aixm:azimuth ancestor and an aixm:dmetimeslice parent, the NARROW_2 value will be written in aixm:type.
However, if the field has an aixm:azimuth ancestor and an aixm:azimuthtimeslice parent, the NARROW value will be written in aixm:type.
