Assign alpha designations
Assigning meaningful designations to items of interest in a given area is crucial to the success of a task that involves cataloging found items. Clearing Grids allows you to assign sequential designations to features at the time of collection without directly editing feature attributes.
Set up the data to collect features
Feature classes are used to store designations for points of interest. You can create a feature class or add a field to an existing feature class.
Create a feature class
To create a feature class to store alpha designations, complete the following steps:
  1. On the ribbon, click the tab where you added the Clearing Grids tools, and click Open Clearing Grids .
  2. Click the Alpha button .
  3. Click the Add New Layer button .
    The Select Output dialog box appears.
  4. Provide a layer name.
    注意:
    When you create a layer, a field is automatically created to store the values for feature designations.
  5. Click Save.
Add a field to an existing feature class
To add a new field, complete the following steps:
  1. Click the Add Field button .
    The Add Field dialog box appears.
  2. Provide a field name.
  3. Click OK.
Collect points of interest and assign designations
To collect points of interest on a map, complete the following steps:
  1. From the Layer drop-down list, select the layer to use to collect points of interest.
  2. From the Field drop-down list, select the field that will store designations for the points of interest.
  3. Set a Start/Next value.
    After you begin assigning designations, the Start/Next input box can be used to skip values. The Start/Next input box can also be used to preview the next value that will be assigned.
  4. To omit values, use the Clearing Grids options dialog box.
  5. Select a Sequence Type option.
  6. Click the Add Letter button .
  7. Click the map to collect a point of interest.
