Scale Minimum: Radar Range method
The Radar Range method applies the SCAMIN values dynamically by taking the compilation scale of the S-57 product, or the M_CSCL feature within the product, and derives a feature's SCAMIN value based on a combination of rules and the two tables (Standard Radar Range and SCAMIN value) contained in the .SCAMIN.xml file.
Consider the following when configuring rules in the SCAMIN.xml file:
  • Compilation scale value of the S-57 cell, or the M_CSCL feature
  • Standard Radar Scale table and SCAMIN Value table
  • Rule type
  • Syntax for the rules
  • M_CSCL features
Compilation scale of S-57 cell or M_CSCL features
With the Radar Range method of calculation, the calculation is based on the compilation scale value of either the S-57 cell or the M_CSCL feature contained in the cell.
Standard radar scale and SCAMIN value tables
The compilation scale value of the S-57 cell, or the M_CSCL feature in the S-57 cell, is rounded to the nearest larger standard radar range value based on a table of radar scales. If an object falls between two of the radar scales below, the next larger scale is selected. For example, if the compilation scale of the S-57 cell or M_CSCL feature is 1:25,000, the radar scale used to determine the SCAMIN value is 1:22,000.
Standard radar scale (rounded)
1:3,000,000
1:1,500,000
1:700,000
1:350,000
1:180,000
1:90,000
1:45,000
1:22,000
1:12,000
1:8000
1:4000
The standard radar scale is used as the starting point in the SCAMIN value table to determine the value set on a given feature. The table lists 22 specific SCAMIN scale values that are used in conjunction with rules or step values specified in the SCAMIN.xml file. The step values are used as a counter in the SCAMIN value table to determine how many scale values smaller than that object should be displayed.
For example, if a radar scale value is 1:22,000, the SCAMIN scale value starting position is 1:21,999. If a rule in the SCAMIN XML states that a feature receives a step value of 4, the SCAMIN value for that feature moves four places to a smaller scale, which is 1:89,999 in the table below.
注意:
This may be counterintuitive. Scale is a ratio, so the larger the number, the further the feature is from the actual size; hence, smaller scale.
SCAMIN value
1:19,999,999
1:9,999,999
1:4,999,999
1:2,999,999
1:1,499,999
1:699,999
1:499,999
1:349,999
1:259,999
1:179,999
1:119,999
1:89,999 (step 4)
1:59,999 (step 3)
1:44,999 (step 2)
1:29,999 (step 1)
1:21,999
1:17,999
1:11,999
1:7,999
1:3,999
1:1,999
1:999
Rule types
The following table describes the rule types supported by the Radar Range method, including the S-57 objects, the primitive or geometry type the rule applies to, the condition that the feature needs to meet, and the number of steps being used to determine the SCAMIN value.
Rule type
S-57 object
Primitive
Condition
SCAMIN steps
By feature—Specific S-57 object
ADMARE
Area
No Condition
By feature/attribute—Specific S-57 object with an attribute condition (Rule Type = "A")
AIRARE
Point/Area
If CONVIS = 1 (visually conspicuous)
By spatial location—S-57 object is spatially associated with another feature (Rule Type = "S")
PIPSOL
Point
Covered by an area LNDARE
PIPSOL
Point/Line
Covered by an area DEPARE, DRGARE, or UNSARE
By both spatial location and attribute condition
BRIDGE
Point/Line/Area
Attribute CONVIS = 1 and covered by an area LNDARE
BRIDGE
Point/Line/Area
Attribute CONRAD = 1 and covered by an area LNDARE
By feature relationship (structure-equipment) (Rule Type = "R")
TOPMAR
Point
Relationship Rule Condition: Equipment features reflect the Structure feature's SCAMIN value.
BOYISD
Point
Structure Feature Relationship Rule contains the overriding SCAMIN value for both features.
Rule syntax
The following are syntax examples for the rule types supported by the Radar Range method.
When defining a rule with attribute conditions, the attribute conditions should be listed based on ascending step values. For example, conditional step value = 1 should be followed by conditional step value = 2, 3, 4, and so on. This ensures that features meeting more than one attribute condition are calculated based on the greatest number of steps.
The spatial rule sets contain operators such as Share and Cover. These operators are used to spatially evaluate a feature to determine whether it meets the criteria for a given rule condition.
  • Share—This operator is used to determine whether the S-57 object being evaluated by the rule shares a common boundary (edge or point) with the object listed in the rule's spatial condition.
  • Cover—This operator is used to determine whether the S-57 object being evaluated by the rule is completely covered by the object listed in the rule's spatial condition.
In the following example, if DAMCON_Dam Line or Area has a common boundary with NaturalFeaturesA|LNDARE_LandArea and DepthsA|DEPARE_DepthArea, the Share spatial operator is placed in the spatial rule.
<Object Name="DAMCON_Dam" PrimitiveType="Line|Area" HasCondition="true" DefaultStepValue="1">
<Conditions>
<Condition StepValue="NULL">
<Rules>
  <Rule Type="S" Object="NaturalFeaturesA|LNDARE_LandArea" Operator="share" />
  <Rule Type="S" Object="DepthsA|DEPARE_DepthArea" Operator="share" />
</Rules>
</Condition>
In the following example, if LOGPON_LogPond Point or Area is completely covered by a DepthsA|DEPARE_DepthArea, the Cover spatial operator is placed in the spatial rule.
<Object Name="LOGPON_LogPond" PrimitiveType="Point|Area" HasCondition="true" DefaultStepValue="1">
<Conditions>
<Condition StepValue="4">
<Rules>
  <Rule Type="S" Object="DepthsA|DEPARE_DepthArea" Operator="Cover" />
</Rules>
</Condition>
Feature-based rule set
Rule: Evaluates whether the feature is encoded as a specific S-57 object.
In the following rule example, ADMARE_AdministrativeAreaNamed receives three steps.
<Object Name = "ADMARE_AdministrationAreaNamed" PrimitiveType = "Area" HasCondition = "false" DefaultStepValue = "3" />
Feature- or attribute-based rule set
Rule: Evaluates whether the feature is encoded as a specific S-57 object and meets the attribute condition.
In the following rule example, AIRARE_AirportAirfield receives three steps if it meets the attribute condition of CONVIS = 1, or one step if it does not meet the condition.
<Object Name = "AIRARE_AirportAirfield" PrimitiveType = "Point|Area" HasCondition = "true" DefaultStepValue = "1">
      <Conditions>
        <Condition StepValue ="3">
          <Rules>
            <Rule Type ="A" Field ="CONVIS" Operator ="equal" Value ="1" />
          </Rules>
        </Condition>
      </Conditions>
    </Object>
Spatial location-based rule set
Rule: Evaluates whether the feature is encoded as a specific S-57 object and is spatially associated with another feature.
In the following rule example, a PIPSOL_PipelineSubmarineOnLand point feature receives one step if it is covered by LNDARE, or three steps if it is covered by DEPARE, DRGARE, or UNSARE.
<Object Name = "PIPSOL_PipelineSubmarineOnLand" PrimitiveType = "Point" HasCondition = "true" DefaultStepValue = "0">
      <Conditions>
        <Condition StepValue = "1">
          <Rules>
            <Rule Type = "S" Object = "NaturalFeaturesA|LNDARE_LandArea" Operator = "Cover"/>
          </Rules>
        </Condition>
        <Condition StepValue = "3">
          <Rules>
            <Rule Type = "S" Object = "DepthsA|DEPARE_DepthArea" Operator = "Cover"/>
          </Rules>
        </Condition>
          <Rules>
            <Rule Type = "S" Object = "DepthsA|DRGARE_DredgedArea" Operator = "Cover"/>
          </Rules>
        </Condition>
          <Rules>
            <Rule Type = "S" Object = "DepthsA|UNSARE_UnsurveyedArea" Operator = "Cover"/>
          </Rules>
        </Condition>
      </Conditions>
    </Object>
Spatial location and attribute-based rule set
Rule: Evaluates whether the feature is encoded as a specific S-57 object, is spatially associated with another feature, and meets the attribute condition.
In the following rule example, BRIDGE_Bridge receives three steps if it meets the attribute condition of CONVIS = 1 or CONRAD = 1 AND is covered by LNDARE.
<ObjectMap>
     <Object Name = "BRIDGE_Bridge" PrimitiveType = "Point|Line|Area" HasCondition = "true" DefaultStepValue = "0" >
          <Rules>
            <Rule Type = "A" Field = "CONVIS" Operator = "equal" Value = "1" />
          </Rules>
        </Condition>
          <Rules>
            <Rule Type = "A" Field = "CONRAD" Operator = "equal" Value = "1" />
          </Rules>
        </Condition>
    </Object>
Feature relationship-based rule set
Rule: An equipment feature's SCAMIN value matches that of the structure feature.
In the following rule example, TOPMAR_Topmark receives three steps if it is a stand-alone feature, or it receives the number of steps of its associated structure feature (four steps).
<Object Name = "TOPMAR_Topmark" PrimitiveType = "Point" HasCondition = "true" DefaultStepValue = "3">
      <Conditions>
        <Condition>
          <Rules>
            <Rule Type ="R" />
          </Rules>
        </Condition>
      </Conditions>
This is the structure feature for the above TOPMAR_Topmark.
<Object Name = "BOYISD_BuoyIsolatedDanger" PrimitiveType = "Point" HasCondition = "false" DefaultStepValue = "4" />
SCAMIN and unit conversion
The Radar Range method is based on S-65 guidance and introduces rule conditions that evaluate features based on two Depth Units (DUNI) attribute fields: VALSOU and VALDCO. Since the S-57 specification requires that depth and height attribute fields be encoded with metric values, it can be assumed that the values listed in the S-65 recommendations are metric.
When unit conversion is used, you must update the Radar Range method rule set to ensure that VALSOU and VALDCO are evaluated based on the proper unit of measure. This also applies for any custom attribute conditions you create.
For example, the VALDCO attribute was updated in the following XML excerpt from the Radar Range method rule set to the derived attribute VALDCO_M. The underscore M identifies the attribute units as meters.
<Object Name="DEPCNT_DepthContour" PrimitiveType="Line" HasCondition="true" DefaultStepValue="2">
<Conditions>
<Rules>
<Rule Type="A" Field="VALDCO_M" Operator="equal" Value="0" />
</Rules>
  	</Condition>
<Rules>
 <Rule Type="A" Field="VALDCO_M" Operator="equal" Value="30" />
</Rules>
</Condition>
</Conditions>
</Object>
Default step value
There are two situations that result in the default step value being applied to a given S-57 object:
  • A feature rule (no conditions) is used to encode SCAMIN for the S-57 object.
  • The encoding or spatial disposition of a given S-57 object fails to meet the listed conditions for the defined rule.
Based on the step values used in the S-65 rule set, it is recommended that a value of 1, 2, 3, or 4 be used when defining rules for the Radar Range method. In addition, a value of 0 can be used to meet special situations. Features meeting the conditions for a rule with a step value equal to 0 are exported without a SCAMIN attribute.
M_CSCL features
M_CSCL features are used to indicate that a subset of features in the S-57 cell have a different compilation scale than the main portion of the dataset. Features spatially within these areas are evaluated based on the M_CSCL compilation scale, and this is the compilation scale that the SCAMIN tool uses for basing the Radar Range method of calculations. To support this, all features should be split along M_CSCL boundaries; those that are not are flagged in the SCAMIN log file.
SCAMIN_STEP attribute
The SCAMIN_STEP attribute is a coded value domain at the feature level used to override SCAMIN values calculated on export. The following are the values that you can set for this attribute:
SCAMIN_STEP values
SCAMIN_STEP
NULL
When SCAMIN_STEP is set to <Null>, the feature is processed and the SCAMIN value is set according to the rules defined in the specified SCAMIN configuration file that is used while running the Export Geodatabase to S-57 tool, such as SCAMIN_RadarRange_Method_Sample.xml.
By setting SCAMIN_STEP to (0), the SCAMIN process does not set a SCAMIN value on the feature.
1, 2, 3, or 4
When SCAMIN_STEP is set to (1), (2), (3), or (4), the feature is processed and the SCAMIN value is set to 1, 2, 3, or 4 steps, respectively, beyond the default radar range. The step value increments of these steps are controlled by the SCAMIN configuration file that is used while running the Export Geodatabase to S-57 tool, such as SCAMIN_RadarRange_Method_Sample.xml.
999—Fixed SCAMIN
A fixed SCAMIN value of 999 is set on the feature.
注意:
Additional fixed values are present in the domain, and the domain can be extended to include more values if needed.
