Verify selected features
ArcGIS Maritime ライセンスで利用可能。
The Verify Selected tool changes the verified field value from Not Verified to Verified for the currently selected set of features. If the tool is used in an NIS or checkout replica schema, the value of the NIS_Verified field is set to Verified for all selected features. In all other database types, the tool changes the value of the Verified state field to Verified for the selected set of features.
ヒント:
You can use the Select Unverified tool to select all the features in your workspace that are not verified.
To verify selected features, complete the following steps:
  1. Start ArcGIS Pro.
  2. Open a new or existing project.
  3. Add data from a maritime S-57 geodatabase to the map if necessary.
    The Maritime S-57 tab appears.
  4. On the map, select the features you want to verify.
  5. On the Maritime S-57 tab, in the S-57 Editing group, click Verify Selected to batch verify all edits.
  6. To verify individual edits, use the Attributes pane to browse through the selected features.
  7. Set the NIS_verified attribute to Verified to confirm the edit.
    This attribute also has an alias name of NIS Verified State.
  8. Click Save.
