VectorFieldRenderer
Краткая информация
Визуализирует информацию о направлении и величине потока в растре с помощью векторных символов.
Обсуждение
Указанный набор растровых данных является временным для растрового объекта. Чтобы сделать его постоянным, вы можете вызвать метод растрового объекта save.
Синтаксис
VectorFieldRenderer(raster, {is_uv_components}, {reference_system}, {mass_flow_angle_representation}, {calculation_method}, {symbology_name})
Параметр Объяснение Тип данных
raster
The input raster.
Raster
is_uv_components
Specifies whether the input components represent U-V, or magnitude and direction.
  • True—The input data represents U-V components.
  • False—The input data represents magnitude and direction components. This is the default.
(Значение по умолчанию — None)
Boolean
reference_system
Specifies how the direction component is measured.
  • 1—Direction is measured in arithmetic coordinates. 0° points due east, and 90° points due north.
  • 2—Direction is measured in geographic coordinates. 0° points due north, and 90° points due east.
(Значение по умолчанию — 2)
Integer
Specifies the angle of mass flow.
  • 0—From—The mass is flowing along the angle and moving toward the origin of the reference system. This is sometimes referred to as the meteorological convention.
  • 1—To—The mass is flowing along the angle and moving away from the origin of the reference system. This is sometimes referred to as the oceanographic convention.
(Значение по умолчанию — From)
Integer
calculation_method
Specifies the thinning method to be used to calculate the magnitude and direction value of a tile.
  • Vector Average—The following calculation occurs for each pixel: convert direction and magnitude to U and V components, calculate the averages of U and V for all pixels in a tile, and then convert the average U and average V back to direction and magnitude.
  • Nearest neighbor—Uses the value from the pixels closest to the center of the tile.
  • Bilinear—Bilinear resampling will be performed on the tile.
  • Cubic—Cubic convolution resampling will be performed on the tile.
  • Minimum—The minimum pixel value of the tile.
  • Maximum—The maximum pixel value of the tile.
(Значение по умолчанию — Vector Average)
String
symbology_name
Specifies the name of the symbol depicting direction and magnitude.
  • Single Arrow—A single arrow depicting direction and magnitude.
  • Wind Barb—Wind barbs indicating wind direction and magnitude.
  • Ocean Current—Ocean current symbol indicating current and magnitude.
(Значение по умолчанию — Single Arrow)
String
Возвращаемое значение
Тип данных Объяснение
Raster
Выходной растр показывается в соответствии с вашими параметрами отображения.
Пример кода
VectorFieldRenderer, пример
import arcpy
Stretch_raster = arcpy.ia.Stretch(imagePath1, "PercentClip", None, None, None, None, True, 0.25, 0.75, None, None, None)
