Download and install product files
Доступно с лицензией Aviation Airports.
Product data files provide business rules and a framework for becoming productive by ensuring standardization and consistency across your operations. Preconfigured databases, cartographic templates, applications, and services help you produce high-quality authoritative content that can be used to publish maps, perform analysis, and share the results throughout your organization.
ArcGIS Pro product files work with the extension. Once ArcGIS Pro and the extension are installed and authorized, you can download and install the product files.
Download
Download options can be viewed after you sign in to My Esri.
Примечание:
You must have the appropriate privileges to access downloads from your My Esri account.
Sign in to My Esri.
Click the Downloads tab.
A list of the latest versions for various software options appears.
Click the software with the product files you want to download.
The expanded Product components node for the software appears. Downloadable content is organized by node.
Locate the extension in the Data and content node, and click Download.
Примечание:
Expand the Data and content node if necessary.
The product files installer download begins.
Install
The downloaded product files contain the setup program.
Start the extraction program you downloaded in the previous steps.
Optionally, change the destination folder for the extraction.
Click Next.
Click Close.
The Launch the setup program check box is checked by default and starts the product file installation.
Примечание:
Uncheck Launch the setup program before clicking Close to run the setup program later. Browse to the location of the installer to launch the installer (
.msifile) at a later time.The setup program Destination Folder page appears with the default installation location prepopulated:
C:\Users\Public\Public DocumentsReview the license agreement and accept it if you agree.
Optionally, click Change to choose a different destination folder.
Click Next.
Click Install.
Click Finish.
The product files are installed to the defined location.
ArcGIS Aviation Airports product file folders
The ArcGIS Aviation Airports product files installer contains product files used in airport-related data creation, analysis, and production. The installer copies the following folders to the installation folder:
<installation location>\ArcGIS Aviation Airports\Product Files\<Version>
3DSupport
ArcadeExpressions
- Label
BatchJobs
AMDB
eTOD
FAA18B
Layers
SampleCharts
ICAO
- AOC
Schemas
Styles
Utilities
ArcToolBox
CustomizeOIS
Notebooks
