使用 AWS 工具设置 IAM 角色策略
如果使用 Amazon 身份和访问管理 (IAM) 身份验证来访问由 ArcGIS Enterprise 部署所使用的 AWS 资源,并且这些部署是您在 ArcGIS Enterprise for Amazon Web Services 工具之外配置的,则必须使用 AWS 工具自行配置 IAM 角色和策略。
下面提供了 IAM 策略的示例 JSON 片段。 该示例使用策略文档的 2012-10-17 版本。 如果使用其他版本,则可能需要更改文档格式。
将尖括号 (<>) 内的值替换为部署特定值。
将 Portal for ArcGIS 内容目录存储在 S3 存储段中
要将 Portal for ArcGIS 内容目录存储在 Amazon 简单存储服务 (S3) 存储段中,需要一个具有以下 IAM 策略的 IAM 用户或角色:
 "Version": "2012-10-17",
 "Statement": [
         "Sid": "<statement-id>",
         "Effect": "Allow",
         "Action": [
             "s3:Get*",
             "s3:PutObject",
             "s3:ListBucket",
             "s3:CreateBucket",
             "s3:DeleteObject"
         "Resource": [
             "arn:aws:s3:::<portal-content-bucket-name>/*",
             "arn:aws:s3:::<portal-content-bucket-name>"
在 S3、DynamoDB 和 SQS 中存储 ArcGIS Server 配置存储和共享服务器目录
要使用 AWS 服务存储 ArcGIS Server 配置存储和共享服务目录,您需要一个具有以下 IAM 策略的 IAM 用户或角色:
"Version":"2012-10-17",
"Statement":[
      "Sid":"<statement-id1>",
      "Action":[
         "s3:ListBucket",
         "s3:ListMultipartUploadParts",
         "s3:GetBucketAct",
         "s3:GetBucketLocation",
         "s3:GetBucketPolicy",
         "s3:GetObject",
         "s3:GetLifecycleConfiguration",
         "s3:DeleteObjectTagging",
         "s3:PutBucketTagging",
         "s3:PutObjectTagging",
         "s3:CreateBucket",
         "s3:DeleteBucket",
         "s3:DeleteObject",
         "s3:PutObject",
         "s3:PutLifecycleConfiguration"
      "Effect":"Allow",
      "Resource":[
         "arn:aws:s3:::arcgis-config-store-*",
         "arn:aws:s3:::arcgis-config-store-*/*"
      "Sid":"<statement-id2>",
      "Action":[
         "dynamodb:DescribeTable",
         "dynamodb:GetItem",
         "dynamodb:GetRecords",
         "dynamodb:Query",
         "dynamodb:CreateTable",
         "dynamodb:DeleteItem",
         "dynamodb:DeleteTable",
         "dynamodb:ListTables",
         "dynamodb:PutItem",
         "dynamodb:Scan",
         "dynamodb:UpdateItem",
         "dynamodb:UpdateTable",
         "dynamodb:TagResource",
         "dynamodb:UntagResource"
      "Effect":"Allow",
      "Resource":[
         "arn:aws:dynamodb:*:*:table/*"
     "Action":[
        "sqs:GetQueueAttributes",
        "sqs:GetQueueUrl",
        "sqs:ListDeadLetterSourceQueues",
        "sqs:ListMessageMoveTasks",
        "sqs:ListQueues",
        "sqs:ListQueueTags",
        "sqs:ReceiveMessage",
        "sqs:CancelMessageMoveTask",
        "sqs:ChangeMessageVisibility",
        "sqs:CreateQueue",
        "sqs:DeleteMessage",
        "sqs:DeleteQueue",
        "sqs:PurgeQueue",
        "sqs:SendMessage",
        "sqs:SetQueueAttributes",
        "sqs:StartMessageMoveTask",
        "sqs:TagQueue",
        "sqs:UntagQueue"
      "Effect": "Allow",
      "Resource":[
         "arn:aws:sql:*:*:SQS/ArcGIS-GP*"
将 S3 存储段用作对象存储
要将 S3 存储段注册为 ArcGIS Enterprise 部署的系统对象存储,您的 IAM 用户或角色至少需要具有以下 IAM 策略:
 "Statement": [
         "Effect": "Allow",
         "Action": [
             "s3:ListBucket",
             "s3:GetBucketAcl",
             "s3:GetObject",
             "S3:GetLifecycleConfiguration",
             "s3:CreateBucket",
             "s3:DeleteBucket",
             "s3:DeleteObject",
             "s3:PutObject",
             "S3:PutLifecycleConfiguration"
         "Resource": [
             "arn:aws:s3:::<object-bucket-name>/*",
             "arn:aws:s3:::<object-bucket-name>"
将缓存存储在 S3 存储段中
要将 S3 存储段注册为云存储以用于存储和访问地图和图像缓存,您的 IAM 用户或角色至少需要具有以下 IAM 策略:
 "Statement": [
         "Effect": "Allow",
         "Action": [
             "s3:PutObject",
             "s3:GetObject",
             "s3:ListBucket",
             "s3:GetBucketAcl",
             "s3:GetObjectVersion",
             "s3:DeleteObject"
         "Resource": [
             "arn:aws:s3:::<cache-bucket-name>/*",
             "arn:aws:s3:::<cache-bucket-name>"
将 S3 存储段用作栅格存储
要将 S3 存储段注册为栅格存储,您的 IAM 用户或角色至少需要具有以下 IAM 策略:
 "Statement": [
         "Effect": "Allow",
         "Action": [
             "s3:PutObject",
             "s3:GetObject",
             "s3:ListBucket",
             "s3:GetBucketAcl",
         "Resource": [
             "arn:aws:s3:::<raster-store-bucket-name>/*",
             "arn:aws:s3:::<raster-store-bucket-name>"
为 webgisdr 实用程序生成的备份使用 S3 存储段
如果您使用随 Portal for ArcGIS 安装的 webgisdr 实用程序在 AWS 上的 S3 存储段中创建备份,则您的 IAM 用户或角色需要用于创建备份文件的策略和用于从这些备份文件恢复部署的策略。
以下是使用 webgisdr 实用程序在 S3 存储段中创建备份所需的最低策略设置:
 "Statement": [
         "Effect": "Allow",
         "Action": [
             "s3:PutObject",
             "s3:GetObject",
             "s3:ListBucket",
             "s3:DeleteObject",
             "s3:GetBucketAcl",
             "s3:PutObjectAcl"
         "Resource": [
             "arn:aws:s3:::<webgisdr-bucket-name>",
             "arn:aws:s3:::<portal-content-backup-bucket-name>",
             "arn:aws:s3:::<webgisdr-bucket-name>/*",
             "arn:aws:s3:::<portal-content-backup-bucket-name>/*"
以下是使用 webgisdr 实用程序从存储在 S3 存储段中的备份文件恢复部署所需的最低策略设置:
 "Statement": [
         "Effect": "Allow",
         "Action": [
             "s3:GetObject",
             "s3:ListBucket",
             "s3:GetBucketAcl",
             "s3:PutObject",
             "s3:DeleteObject"
         "Resource": [
