Run reports and infographics
需要具有 Business Analyst 许可才能使用。
Reports and infographics allow you to visualize and analyze key information about geographic areas, such as polygons and trade areas. You can run predesigned templates, import and run custom templates from Business Analyst Web App, or run infographics and reports that you built in ArcGIS Business Analyst Pro. You can run a report or infographic using online or local datasets, populating it with data from Esri demographic data portfolios, ArcGIS content, and custom data from statistical data collections.
You can export infographics and reports that are included with Business Analyst, those shared with you by other users, and those that you created. Infographics and reports can be formatted as .pdf, .xlsx, .html, simple .xml, .zip, .csv, and .pagx files.
To run infographics and reports, complete the following steps:
On the Analysis tab, in the Geoprocessing group, click Tools.
The Geoprocessing pane appears.
On the Toolboxes tab, in the Business Analyst Tools section, expand the Reports toolset and click Summary Reports.
In the Summary Reports pane, use the Boundary Layer drop-down menu to choose a layer that contains the areas on which to run reports and infographics.
Use the Create Reports drop-down menu to select a report or infographic to run. You can also use the Add Many button
to select multiple reports and infographics and click Add.You can select report and infographic templates in the following sections:
Esri Reports—Ready-to-use reports included with ArcGIS Business Analyst Pro.
Standard Infographics—Ready-to-use infographics included with ArcGIS Business Analyst Pro.
My Reports—Templates created or imported by you. Templates in this section vary based on your selected data source:
If you are using locally stored data, this section includes infographic and report templates created in ArcGIS Business Analyst Pro and templates you imported from Business Analyst Web App.
If you are using online data, this section includes templates created and saved in Business Analyst Web App.
Shared Reports—Templates shared with you by others in your organization. This section is only available when using online data.
Optionally, use the Site Name Field parameter to specify the field that populates for site names in infographics and reports.
The site name is often used in report and infographic headers, identifying the site that corresponds to the data displayed in the infographic or report.
For the Output Folder parameter, specify a destination for saving the reports and infographics.
The default destination is the current project folder.
Optionally, expand the Report Formatting section and do the following:
Use the Summarization Options drop-down menu to specify whether to create reports for individual features, the whole layer, or both. Check the Single Report parameter to combine all report content into a unified document.
Use the Report Output Formats parameter to specify the format of the report or infographic. The default export format is PDF.
Use the Preferred Report Style drop-down menu to select Classic or Modern as the report style. The modern report style updates classic reports to a presentation-ready design. This style is only available when running Esri reports.
Optionally, expand the Report Header Options section to specify fields in the report:
Store ID Field—A field that contains information that uniquely identifies each store or point location. You may want to open the pop-up for a point to assess which field is most appropriate, such as the field containing the store name.
Store Address Field—The field that contains the address of the point location the report is being run on.
Store Latitude Field—The field that contains the latitude coordinate for the point location the report is being run on.
Ring ID Field—The field that contains the identifying information for which ring in a multi-ring site the report is being run on. For example, a point location might have 1- and 3-mile rings around it. The Ring ID Field may be populated with 1 or 3 to specify the ring containing the geographic area for which the report shows data.
Area Description Field—The field that contains descriptive information about the site area.
Report Title—A title to add to each report.
Report Subtitle—A subtitle to add to each report. The default is Prepared by ArcGIS Business Analyst Pro.
Optionally, expand the Infographic Options section to specify additional content to include in infographics:
Add Infographic Header—Adds a header containing the text Prepared by ArcGIS Business Analyst Pro.
Add Infographic Footer—Adds a footer containing the template's copyright year, the page count, and the date the infographic was run.
Add Infographic Data Source—Adds vintage year information for data included in the infographic.
Click Run.
The selected infographics and reports are run and saved in the specified output folder.
To view the infographics and reports, click View Details in the Summary Reports completed message, and select the output files.
注:
You can also run infographics from the Map tab, in the Inquiry group, by clicking Infographics
to interactively view infographic templates.
