Convert airport sign labels to annotation
需具备 Aviation Airports 许可方可使用。
You can convert AirportSign feature class labels to annotation using the Convert Labels to Annotation tool. Annotation provides a more precise placement of individual features than label classes. By creating feature-linked annotation, you can edit the AirportSign features and keep the AirportSign annotation updated.
The Convert Labels to Annotation tool outputs a new feature-linked annotation feature class containing classes corresponding to the label classes in the source AirportSign feature class.
To convert airport sign labels to annotation, complete the following steps:
In the Contents pane, click the List By Labeling button
.注:
Ensure that the AirportSign layer is checked along with its FRONT and BACK label classes.
In the Labeling group under the Map tab, click the Convert Labels to Annotation button
.The Convert Labels to Annotation dialog box appears.
Set the Input Map parameter to the map containing the AirportSign layer with the label classes that need to be converted.
Set the Conversion Scale parameter to the annotation reference scale.
Click the Convert drop-down arrow, and choose Single Layer.
Click the Feature Layer drop-down arrow, and choose the source AirportSign layer.
Set the Output Geodatabase parameter to the geodatabase containing the source AirportSign feature class.
For the Annotation Suffix parameter, provide a text string to be appended to the AirportSign layer name to create the name of the output annotation feature class.
The default is Anno.
Specify an extent, or click the Extent drop-down arrow and choose an option.
If only the labeled features should generate annotation, ensure that the Convert unplaced labels to unplaced annotation parameter is unchecked. This is the default.
注:
If checked, the unplaced labels are converted to unplaced annotation and stored in the annotation feature class. The
Statusfield for these annotations is set to Unplaced.Optionally, check the Require symbols to be selected from the symbol table parameter.
When checked, this allows edits to symbol properties that enable annotation features so that they keep referencing their associated text symbol in the collection.
注:
If you don't check this check box, all text symbols can be edited. This is the default.
Optionally, check the Create feature-linked annotation parameter.
This parameter is only available with ArcGIS Desktop Standard and ArcGIS Desktop Advanced licenses.
The Create annotation when new features are added and Update annotation when feature's shape is modified parameters appear and are checked by default.
注意:
Feature-linked annotation may introduce editing limitations in a geodatabase.
Provide a name for the group layer with the new feature-linked annotation that is added to the map.
Optionally, accept the default, GroupAnno.
Click Run.
