Manage relationships
需具备 ArcGIS Maritime 许可方可使用。
The Relationship Manager pane lists existing relationships in each loaded workspace based on the viewing options.
Access the Relationship Manager pane
Complete these steps to access the Relationship Manager pane:
Start ArcGIS Pro.
Open a new or existing project.
Add data from a maritime S-57 geodatabase to the map if necessary.
The Maritime S-57 tab appears.
On the Maritime S-57 tab, in the S-57 Editing group, click Relationship Manager
.The Relationship Manager pane appears.
Display relationships by selection or extent
You can view all existing relationships in your database by selection set or extent.
In the View Relationships By section, choose one of the following:
Selection—View relationships by selection set.
Extent—View relationships by extent.
Click Refresh
to display the list based on the option you chose.The list of relationships in the Relationship Manager pane is refreshed.
提示:
This allows you to change the extent and selection in the map but still work with the same list of features in the Relationship Manager pane.
Right-click a selected relationship in the Relationship Manager pane and click Zoom To
or click Pan To
to go to the current item.
Choose relationships and features
There are several ways to choose features in the Relationship Manager pane. You can select an entire structure-equipment or collection relationship at one time, or you can select individual structure, equipment, or collection features.
Function |
Description |
Select All Features |
Select all features that participate in that relationship. |
Select Feature |
Select a single feature from the relationship. |
Add All to Selection |
Add all features that participate in a relationship to the selection. |
Add to Selection |
Add the selected feature to the current selection set. |
