Override SCAMIN
需具备 ArcGIS Maritime 许可方可使用。
The SCAMIN_STEP property is a coded value domain at the feature level used to override SCAMIN values calculated on export. The following are the values that you can set for this property:
SCAMIN_STEP values
SCAMIN_STEP
NULL
When SCAMIN_STEP is set to <Null>, the feature is processed and the SCAMIN value is set according to the rules defined in the specified SCAMIN configuration file that is used while running the Export Geodatabase to S-57 tool, such as SCAMIN_RadarRange_Method_Sample.xml.
By setting SCAMIN_STEP to (0), the SCAMIN process does not set a SCAMIN value on the feature.
1, 2, 3, or 4
When SCAMIN_STEP is set to (1), (2), (3), or (4), the feature is processed and the SCAMIN value is set to 1, 2, 3, or 4 steps, respectively, beyond the default radar range. The step value increments of these steps are controlled by the SCAMIN configuration file that is used while running the Export Geodatabase to S-57 tool, such as SCAMIN_RadarRange_Method_Sample.xml.
999—Fixed SCAMIN
A fixed SCAMIN value of 999 is set on the feature.
注:
Additional fixed values are present in the domain, and the domain can be extended to include more values if needed.
Complete the following steps to override the SCAMIN value:
  1. Start ArcGIS Pro.
  2. Open a new or existing project.
  3. Add data from a maritime S-57 geodatabase to the map if necessary.
    The Maritime S-57 tab appears.
  4. Select a feature on the map.
  5. On the Maritime S-57 tab, in the Selection group, click the Attributes button .
    The Attributes pane appears.
  6. In the Maritime Attributes section, locate the SCAMIN attribute.
    The SCAMIN attribute is in the S-57 Attributes group.
  7. Change the attribute value.
  8. Click Apply.
  9. Save the changes.
