FAA 13A Runway Protection Surfaces (Aviation Tools)
汇总
Generates runway protection surfaces based on FAA Advisory Circular 150/5300-13A.
Safe and efficient landing and takeoff operations at an airport require that certain areas on and near the airport are clear of objects or restricted to objects with a certain function, composition, or height. These clearing standards and criteria are established to create a safer environment for the aircraft operating on or near the airport.
旧版本:
This is a deprecated tool. This functionality has been replaced by the FAA 13 Runway Protection Surfaces tool that generates runway protection surfaces based on FAA Advisory Circular AC 150/5300-13B.
用法
This tool generates runway protection surfaces based on design matrices defined by the FAA. A design matrix consists of an approach category and approach design group. You can specify the design matrix to use for the surfaces by setting the Approach Category and Approach Design Group parameters.
Some design matrices only apply to aircraft under 12,500 pounds. You can use the Small Aircraft parameter to specify the design matrix for a small aircraft.
The Input Runway Features parameter value must be z-enabled.
The Target OIS Features parameter value must be z-enabled.
This tool creates the runway protection area surface in an existing polygon or multipatch feature class. If a feature class is used for the Target OIS Features parameter value, it must have a vertical spatial reference. It should have
NameandDescriptiontext attributes, which will be populated in the output features. Suitable Target OIS Features parameter values can be the following feature classes from the Esri Airports schema (Airports18B_NAD83_GX.xml): Airspace\ObstructionIdSurface, ObstructionIdSurface_MP, or RunwayProtectArea.If the Runway End Features parameter is specified, the corresponding field values in this layer will override the values specified in the Approach Category, Aircraft Design Group, and Approach Guidance parameters. This is useful for providing specific input per runway end. The Airfield\RunwayEnd feature class is suitable input for this parameter with the following fields populated:
Approach Category,Approach Guidance, andDesign Group.The high end of the runway refers to runway direction identifiers 19 through 36. The low end of the runway refers to runway direction identifiers 01 through 18.
To create a
.jsonfile for the Custom JSON File parameter, use theCustomizeOIS.exeutility included in the Aviation Airports Product Data download available from My Esri.
参数
| 标注 | 说明 | 数据类型 |
Input Runway Features |
The input runway dataset. The feature class must be z-enabled and contain polylines. |
Feature Layer |
Target OIS Features |
The target feature class that will contain the generated OIS. |
Feature Layer |
Surface Generation (可选) |
Specifies the type of surface that will be generated.
String |
Visibility Minimums |
Specifies the visibility minimums that will be used for the runways.
String |
Approach Category |
Specifies the approach category that will be used to generate surfaces.
String |
Aircraft Design Group |
Specifies the approach design group that will be used to generate surfaces.
String |
Small Aircraft (可选) |
Specifies whether surfaces will be generated with the small aircraft design matrix. 注:This parameter only applies when the
Boolean |
Approach Guidance (可选) |
Specifies the type of approach guidance that will be used at the end of the runway.
String |
Runway Direction (可选) |
Specifies the end of the runway where the approach surface will be created.
String |
Airport Elevation (可选) |
The highest elevation on any of the runways of the airport. The value should be in the vertical coordinate system linear units of the target feature class. If no value is provided, the highest point from the Input Runway Features parameter value will be used. |
Double |
Input Airport Control Point Feature (可选) |
The point features containing an Airport Elevation parameter feature, displaced threshold features, or both. The value provided for the Airport Elevation parameter will take precedence over these point features. |
Feature Layer |
Runway End Features (可选) |
The input runway end point features associated with each runway. The corresponding field values in this layer will override the values specified in the Approach Category, Aircraft Design Group, and Approach Guidance parameters. |
Feature Layer |
Last Low End Approach Light (可选) |
The distance in feet of the Approach Lighting System (ALS) from the end of the low end of the runway. If no value is provided, it is assumed that there is no ALS at the low end of the runway. |
Double |
Last High End Approach Light (可选) |
The distance in feet of the Approach Lighting System (ALS) from the end of the high end of the runway. If no value is provided, it is assumed that there is no ALS at the high end of the runway. |
Double |
Custom JSON File (可选) |
The import configuration, in JSON format, that will be used to create the custom obstruction identification surface (OIS). |
File |
派生输出
| 标注 | 说明 | 数据类型 |
Output OIS Features |
The output obstruction identification surface (OIS) features. |
Feature Layer |
环境
此工具不使用任何地理处理环境。
许可信息
- 基本: No
- 标准: Requires Airports or ArcGIS Aviation Charting
- 高级: Requires Airports or ArcGIS Aviation Charting
