Generate Procedure Leg Geometry (Aviation Tools)
汇总
Generates geometry from procedure legs to correct loaded AIXM data lacking proper geometry.
This tool analyzes each selected procedure leg geometry based on the TYPE_CODE and the corresponding ARINC 424 geometry definition. This tool will navigate the relationships to appropriate point features, angle or distance indication rows based on the Procedure leg point geometry relationship. The tool will then create geometry for the feature and updated as appropriate based on the presence of existing geometry.
用法
  • All input feature classes require the attributes in the ArcGIS Aviation AIS schema.
    Learn more about the AIS schema
  • The type of geometry created will be based on the Procedure Leg parameter value's TYPE_CODE field, which corresponds to the 22 possible ARINC 424 procedure leg types. Each type has a specific definition of how the geometry is created from its corresponding point and bearing inputs.
  • The tool will only update the existing geometry of features when the Overwrite Existing Geometry parameter is checked.
参数
标注 说明 数据类型
Procedure Leg
The feature layer containing the procedure leg segments.
Feature Layer
Procedure Leg Point
The feature layer containing the procedure leg points.
Feature Layer
Designated Point
The feature layer containing point features that start or end route segment features.
Feature Layer
Navaid System
The feature layer containing the navigational aid system (NAVAID) components.
Feature Layer
ADHP Threshold
The feature layer containing the markers on a runway indicating the landing touchdown points.
Feature Layer
ADHP
The input ADHP (aerodrome or heliport) features.
Feature Layer
Navaid Indication
The NAVAID indication table.
Table View
(可选)
Specifies whether the geometry will be overwritten.
  • 选中—The geometry will be overwritten.
  • 未选中—The geometry will not be overwritten. This is the default.
Boolean
派生输出
标注 说明 数据类型
Updated Procedure Leg
The output feature class containing the updated procedure leg features.
Feature Class
环境
此工具不使用任何地理处理环境。
许可信息
  • 基本: No
  • 标准: Requires ArcGIS Aviation Charting
  • 高级: Requires ArcGIS Aviation Charting
