Group Route Segments (Aviation Tools)
汇总
Derives additional cumulative information, such as the total distance of a route or route portion from individual segments, to prepare data for charting.
This tool identifies routes and route portions in FAA and NGA ATSRoute data.
A route collection is an ordered set of ATSRoute segments from a NAVAID to a NAVAID. For each route collection identified, an entry will be stored in the EnrouteInformation stand-alone table with the total calculated distance of each group.
A route portion collection is a subset of an en route collection containing segments from a compulsory point to a compulsory point. A route portion can also go from a NAVAID or compulsory point to a NAVAID or compulsory point. For each route portion collection identified, an entry will be stored in the RoutePortion stand-alone table.
用法
  • The tool requires the following feature classes, tables, and attributes:
    Name
    Required fields
    ATSRoute—Feature class
    • IDENT_TXT
    • EnrouteInformation_Id
    • StartPoint_Id
    • EndPoint_Id
    • RepATCStart_Code
    • RepATCEnd_Code
    EnrouteInformation—Stand-alone table
    • GFID
    • Distance_Val
    RoutePortion—Stand-alone table
    • GFID
    • Distance_Val
    • StartPoint_Id
    • EndPoint_Id
    DesigPoint_NavaidAssoc—Attributed relationship class
    • DesignatedPoint_ID
    • NavaidRole_Code
    The DesigPoint_NavaidAssoc relationship class is required to determine the collocation of a designated point with a NAVAID. A NavaidRole_Code attribute value of 2 indicates that a given DesignedPoint is collocated with a NAVAID.
    If required attributes are missing, an error occurs listing the dataset name and missing attributes.
    注:
    The ArcGIS Aviation Charting product files contain additional information about the AIS schemas that are available for download.
    注意:
    This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
参数
标注 说明 数据类型
Target ATS Route Features
The input feature class for the ATSRoute feature class that contains polylines. The EnrouteInformation_Id and the RoutePortion_Id attributes will be updated.
Feature Layer
Target Enrouteinformation Table
The table that will be updated to contain entries for the en route segments identified during processing. The Distance_Val attribute is set to the total length of the en route segments.
The Distance_Val attribute is updated and kept up to date on new and existing en route segments.
Table View
Target RoutePortion Table
The table that will be updated to contain entries for the route portions identified during processing. The Distance_Val attribute is set to the total length of the route portions' segments. The route portions' StartPoint_Id and EndPoint_Id attributes will also be updated to refer to the start and end point of a route portion.
Table View
Designated Point Navaid Association Table
The DesigPoint_NavaidAssoc association table that contains the relationships between designated points and NAVAID systems. The ATSRoute feature class's start and end designated point's GFID field will reference entries in this table. This table indicates whether a point is collocated with a NAVAID and helps determine the grouping of route segments.
Table View
派生输出
标注 说明 数据类型
Modified Target ATS Route Features
The target ATSRoute feature layer with updated fields.
Feature Layer
Modified Target Enrouteinformation Table
The target Enrouteinformation table with updated fields.
Table View
Modified Target RoutePortion Table
The target RoutePortion table with updated fields.
Table View
环境
此工具不使用任何地理处理环境。
许可信息
  • 基本: No
  • 标准: Requires ArcGIS Aviation Charting
  • 高级: Requires ArcGIS Aviation Charting
