PAPI Obstacle Clearance Surface (Aviation Tools)
汇总
Creates a Precision Approach Path Indicator (PAPI) Obstacle Clearance Surface (OCS) based on the FAA Engineering Brief (EB) 95.
A PAPI OCS determines which objects are vertical obstructions. An object is considered a vertical obstruction if it penetrates the PAPI OCS. Surfaces are used to support planning and design activities.
用法
  • The Input Runway Features parameter must be z-enabled.
  • This tool creates the obstruction identification surfaces (OIS) in an existing polygon or multipatch feature class. They can also be generated in an existing polygon shapefile. If a feature class is selected for the Target OIS Features parameter value, it must have a vertical spatial reference.
  • OIS tools are flexible and accept a variety of input and output feature class types. For more information, see the OIS Input and Output schemas.
  • The Input Airport Control Point Feature parameter can be used to supply x-, y-, and z-geometry for displaced threshold features. If displaced thresholds are included, surfaces will be constructed based on their x-, y-, and z-geometry instead of their corresponding runway feature endpoint.
参数
标注 说明 数据类型
The input runway dataset. The feature class must be z-enabled and contain polylines.
Feature Layer
Target OIS Features
The target feature class that will contain the generated OIS.
Feature Layer
Runway Direction
(可选)
Specifies the end of the runway where the approach surface will be created.
  • High Runway End Designator—The approach surface will be created at the high end of the runway. This is the default
  • Low Runway End Designator—The approach surface will be created at the low end of the runway.
String
Length
(可选)
The length of the surface in miles. The default is 4.
Double
Divergence
(可选)
The divergence of the surface in degrees. The default is 10.
Double
Slope
(可选)
The slope of the surface in degrees. The default is 3.
Double
Distance From Threshold
(可选)
The distance from the threshold in feet. The default is 700.
Double
Start Height
(可选)
The start height of the surface in feet. The default is 35.
Double
(可选)
Supplies x-, y-, and z-geometry for displaced threshold features. If displaced thresholds are included, surfaces will be constructed based on their x-, y-, and z-geometry instead of their corresponding runway feature endpoint.
Feature Layer
派生输出
标注 说明 数据类型
Output OIS Features
The updated feature class containing the generated obstruction identification surface.
Feature Layer
环境
此工具不使用任何地理处理环境。
许可信息
  • 基本: No
  • 标准: Requires Airports or ArcGIS Aviation Charting
  • 高级: Requires Airports or ArcGIS Aviation Charting
